Question about Kenmore Dryers
Running, but not heating - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
Does outside unit run when thermostat calls for auxiliary heat ?
do not think so . that unit is usually for cooling .
Apr 03, 2018 | Heating & Cooling
I have a thermostat RTH9580. Why do I have emergency heat under system AND heat which sometines switch automatically to auxilliary heat?
If you have an air to air heat pump, in colder temperatures, the heat pump will not heat as well as it would in warmer outdoor temperatures making it run longer. the digital thermostats work off of a built in algorithm that kicks on the auxiliary heat when the heat pump runs to long so that it will satisfy the thermostat quicker. This can be tied to the Emergency heat @ the thermostat energizing a few heating elements, or just energizing a separate element from the emergency heat. I always recommend on an air to air heat pump to run the emergency heat when you have consistent Outdoor temperatures below 20 degrees F because you will cycle the heat less by getting hotter heat making life more comfortable, and it costs about the same as running the heat pump since @ those temperatures, it will run all the time.
Jan 09, 2015 | Honeywell 7 Day Touch Screen Programmable...
Why is my Duo Therm Heat Pump Running in Aux Heat Mode?
If the compressor is running in heat mode but not producing any heat then the change over valve may be stuck. That is a job for a pro. If the thermostat isn't applying power to the changeover valve then a thermostat change is easy to do.
Aug 18, 2014 | Heating & Cooling
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
What will happen if thermostat will be removed and
Good question: The thermostate acts as a valve (of sorts) allowing the engine to stay at a relative constant temp. If run without an engine will typically run too cool (this is not good as engines are designed to run at specific heats for best efficiency and motor oil too is designed to run a a designed heat. An engine can go the other way too and over heat. As mentioned the thermostate acts like a valve controling the flow of coolant thru the block and radiator. The run thru block is a long one and it will certainly pick-up heat however running without may cause the coolant to run too quickly thru the radiator so little heat will be lost. (imagine a lit candle run your finger thru it quickly and no heat exchange as it you will not burn your finger, slower you'll get the heat from the candle and burn your finger. In short use a thermostate, your engine was trully engineered to have one.
I hope this expalins it for you,
Tom
Jun 02, 2010 | 2006 Mitsubishi Lancer
Heat pump runs in em heat when outside temperature is low
Yes, you may turn to em heat only. May this confirmation help you.
Jan 06, 2010 | Heating & Cooling
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Feb 19, 2009 | Sharp CV-P09FX Air Conditioner
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
