I have a old emachine desktop and whenever i turn the monitor on it just says self test check your pc and signal cable monitor working. i have everything set up correctly and it still doesn't work.
  • Katiemom5 Oct 29, 2008
    My mother in law has described the exact problem to me and wants me to help her fix it! ??? I dont know what to do.
  • Anonymous Apr 18, 2009
    i have the same problem with my emachine. the computer itself runs but the moniter just shows that message and i dont know what to do
Replace the little watch battery thats in it open the case and you will see it $2.35 at wal mart. mine was doing the same thing fixed it in about 15 min. open the case and you will see it
Posted on Aug 05, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
The monitor i see selt test G check your
Connect the monitor to a different computer, e.g., a laptop, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your video-card is outputting any signals.
May 10, 2011 | E-Machines eMachines Desktop PC
Emachines computer problem
have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
Mar 04, 2009 | E-Machines eMachines Desktop PC
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
You asked for more info
I think you're Emachine is just using the internal video output that came with it, better get this GeForce 7100 GS Video Card ..
Good luck............
Aug 26, 2008 | E-Machines eMachines Desktop PC
Alarm for failed monitor when I turn on the pc
PC is not producing and video signal - can you test it with another monitor or test monitor on another PC or notebook.
Is graphics card in PC loose?
Aug 09, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
202 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
