Question about MSR Reactor Stove System Backpacking Stove
I used my MSR reactor burner a couple of times with no problems,and i thought it was the greatest, but as i was using it the third time,the stove just simply went out,stopped working and haven't lit since,tried new fuel canisters but still doesn't light.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 190 Answers
The nozzle on this and other canister stoves can clog. Check the manual to determine how to clean the nozzle.
Hope this helps.
Posted on Apr 27, 2011
The left front burner on my stove heats up when it is not in use. It is an electric stove.
Hi Teresa Rhodes- Smith -Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, I strongly suggest contacting a professional to move forward accurately and to assist with the repairs and to refrain from using the unit. The range could possibly be experiencing a communication error with the EOC, wiring failure, or faulty element sensor/switch.
Jan 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My oven and stove top isn't working at all. If I turn a burner on, the clock and oven light up, but the burner doesn't get hot and either does the oven. It's only 8 years old and isn't used often.
I was having this problem and it was because I had tripped the breaker. Reset the breaker (box Inside your home) and try that, However, there is probably an underlying electrical problem that should be fixed asap. I live in an older remodeled mobile home that isn't equipped to handle a lot of appliances going at the same time. Try to make sure you aren't pulling so much power when you use the stove, ex: TV, microwave, oven, stove, all running at the same time.
Nov 19, 2010 | Whirlpool Accubake RF362LXTT Electric...
F5 display not turning burners on
Hi
Thanks for using FixYa. Error F5 means that the control board has failed and to resolve this unfortunately you’ll have to replace the control board. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Same thing with my one and 1/2 year old KGSS907 series stove
Yes it is fixed. Did a temporary jumper of the over temp fuse to use the oven one night. Installed a replacement 130 degree fuse with a mica transistor insuator under it instead of being mounted directly on the back side of the oven. This raised the range to about 150 degrees.
Thanks for the help
Aug 25, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Whirlpool electric range burner exploded ''on'' light on always
Hi There,
While the stove is unplugged remove the bad burner from the stove and set the bad burner's control knob to the "OFF" position. Now plug the stove back in. If there is a problem it should trigger the breaker and shut off the stove. If you are not comfortable doing this you might want to ask someone.
The explosion was due to a shorted burner element and once it is removed there shouldn't be any more problems. I hope this was helpful and I hope you get your stove going again.
Mar 26, 2009 | Kitchen Ranges
Having a problem with burners not generating .
so you have a yellow flame, not blue?
my mate had same problem. He now uses unleaded, adding 10 drops Redex to a gallon.
He was also told not to overfill the tank - just 3/4 full.
Works much better but he says not perfect.
Ian
Aug 24, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
MSR Reactor Stove System Backpacking Stove Logo
652 people viewed this question
Top MSR Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
ray gallant
Betty L Kidd
Betty L Kidd
Are you a MSR Rock and Ice Climbing Expert? Answer questions, earn points and help others
