Question about Dometic Rooftop RV Air Conditioner
I have a Penguin Dometic ac unit mfg # 641515.301c0 and air cover item # 3310741.016 and would like some help wiring the cover to the unit. The cover has a 6 pin plug and the ac unit just has the wires hanging with out the matching plug. What is the proper wires to match up with the cover? Thanks, Steve
  • 68 Answers
SOURCE: My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Posted on Mar 19, 2009
motor1258
  • 6674 Answers
SOURCE: problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
Posted on Aug 07, 2009
icemelts
  • 246 Answers
SOURCE: My 1990 Penguin unit has a leak. Can it be fixed?
Leaks can be repaired, some quite easily and others while difficult to find - and get to - prove somewhat more difficult.
The problem with 'leaks' is sometimes they are 'high pressure leaks' which are some of the more difficult ones to find.
So... the answer to your question is yes - but.
I would try and get a very experienced Service Tech to fix the leak, and one who will stand behind his work.
good luck!
Posted on May 12, 2010
motor1258
  • 6674 Answers
SOURCE: Have a Dometic Penguin on the front of a 5th wheel...
Have you checked for frost on coils/fins when you remove filter at ceiling assy? Non-ducted I presume?
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: have 2 dometic duo-therm 13.5
It would seem as though something in the front unit is killing the circuit boards....
The front circuit board was bad so the control still did not work in the front...then you swapped the circuit board from the back and killed it in the front unit...that is why it will not work in the back now...
There may be a short somewhere in the front unit that is killing the circuit boards...to find the problem you will need to use an OHM meter and trace down the problem...probably as simple as a wire rubbed through or pinched...but a meter may be needed to find it...
heatman101
Posted on Apr 14, 2011
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
AS I SAID BEFORE my problem is not ac connection its the 2 blue ,,2yellow and one red and one black..where to connection these color wires..coming out from the roof top unit. My unit is Dometic Penguin...
Unfortunately I have no access to any previous information you received from other experts, but I will tell you that without knowing which ceiling assembly/control box, thermostat etc., that you are using, the most I can do is tell you this.
Blue wire is for the compressor circuit.
Black wire is for high fan .
Yellow wire is not used, unless for heat pump circuit reversing valve.
Red wire is for low fan.
White is the common AC connection.
Green/yellow striped is for ground to chassis.
Jun 08, 2011 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
80 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
