Question about GE WBSR3140DW Top Load Washer
Wont spin but does agitate and the water drains out
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
Posted on May 01, 2011
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
GE WBSR3140DW Top Load Washer Logo
46 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
