Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Pool spa repeatedly comes on without any input from us...also the air bubbler and some times the light too. what can be done about this?
You may have a bad spa side control
Posted on Mar 24, 2011
Why are bubbles forming in my intex pure spa jet massage?
the air bubbler is switched on
there is a leak in the suction side of the pump that is sucking in air
Sep 14, 2015 | Intex Pool & Spa
How to get a ever flo to pump more oxygen
If you are asking how to pump more bubbles into the pool it shouldnt happen in the first place, if it does you might have a problem/you will soon(will ruin you alkalinity which ruins PH which ruins chlorine). If you are asking about a spa/jacuzzi, it should have a separate bubbler pump for it which will already be running at max if its working properly, check all connections/seals so air is not escaping.
May 26, 2015 | Pool & Spa
My Intex spa,when heat is turned on bubbler runs constantly,until you turn off heat,if you turn on filter jets they work fine, but bubbler kicks on won't stop till you shut them off yourself.
are you sure you didnt plug the blower in the heater outlet on the control box ???
if not i suspect you have a common problem with these units (water intrusion) inside the control box this produces all sort of (gremlins) to happen
Dec 23, 2014 | Intex Pool & Spa
Set a program for pool mode on
go into set up then programming highlight the item you want to make a program for set on time and off time if you want it to run continuously start time 2:00am to 1:59am it will go off for 1 minute then start back up
Apr 13, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Three lights flashing on the control panel
check recirculation pump heater element and pressure switch
Dec 29, 2012 | Heritage Pool & Spa
Spa jets won't bubble
some tubs have a powered blower (you can hear it) or some tubs have a venturi suction bubbler system, you will have have to pop open service cover to look to see what kind you have, venturi type most of the time are turned off or down to far and don't produce bubbles (twist knobs) powered blowers sometimes have hoses pop off there fittings
Jul 28, 2012 | Jacuzzi Pool & Spa
Hello , I have a 5yr old pool complete with Hayward Filter and a 1hp pool filter motor and 2 hp spa air injection motor connected to an air switch the in ground pool is 32K gallons. Problem is with spa air...
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Nov 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pentair lx 100 problems all of the functions have all come on at once the unit will not allow me to turn anything off [spa, air bubbler,lights etc]
This is odd. This is the second one today. Usually I get this question once a month. But it is the control board. The part number is Pentair lx 100 and cost around $200. You can order it where you purchased the spa or online at http://www.firethepoolman.com/cartgenie/prod-17629.htm
Sep 22, 2010 | Pentair Pool & Spa
I have a Jandy Laars LX Pool/Spa Heater...when I try to heat it cycles three times then tells me to call for service...I feel heat coming out of the vent. The pool/spa is connected to a AquaLinks system...
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Mar 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
44 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
