Question about Microsoft Xbox 360 Console
My xbox slim turns on nomrally but the rings won't turn on and the controler doesn't sync.
  • supmf19333 Mar 20, 2011
    I tried it but it didn't work
    President:
  • Microsoft Master
  • 1,623 Answers
Switch on the xbox and press and HOLD the sync button on the front of the xbox for 30 secs. Then try pressing it once to try and sync up your controller again
Posted on Mar 20, 2011
  • Martin Murray Mar 20, 2011
    have you tried another controller, or tried your controller with another xbox?
I took my xbox 360 slim apart to clean the fan heat sinks etc and put all the connections back into the disc reader and put the whole xbox back together but now the controller will not connect. the...
I havn't had the chance to work on a Slim yet, but from my experience with Phat 360s, you should clean out the connectors for the Ring of Light board with alcohol before reattaching it to the motherboard.
Feb 14, 2014 | Microsoft Xbox 360 Console
My Xbox 360 red ringed about four days ago, so I hadn't turned it on since then. I took it home for spring break to try to fix the problem or whatever, but when I turned it on, it didn't give
They can be. If the console is not working properly the controllers usually dont turn on correctly. Try sending it to videogame911.com i used them for my red ring issue with my XBox and got it back within the week. Also they were EXTREMELY low on price compared to the manufacture and offered me a 90 day warranty with all data saved. Hopefully this works for you!
Mar 29, 2013 | Microsoft Xbox 360 Controller
Mx vs atv alive says activate second controller
I guess it's as easy as pressing A or Start.
But if the controller really isn't connected anyways, you have to:
1: Turn on controller, and hold the sync button ( just to the right of the Left Bumper ).
2: Press the Sync button on the Xbox 360
> Slim version: Sync button is placed just beside the usbports on the front of the xbox.
> Original version: The sync button is placed just beside Memory Slot B ( looks pretty much as the one on the xbox controller.
3: The controller should connect and sync automaticly to your Xbox 360.
Jan 10, 2013 | THQ MX vs ATV Alive for Xbox 360
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
I have a brand new controller which came with my new xbox 360 and i have put the batteries in the correct way as instructed but when i press the xbox guide button nothing happens. I have also tried to sync...
The guide button won't work until its synced,you need to push the button on the console to look for controllers then the button on the controller and it will sync it and then it should work fine. If that doesn't work then try hitting the button on the controller first then the one on the console.
May 18, 2011 | Microsoft Xbox 360 Controller
I was at a friends house and I was playing on the original Xbox 360 with my new Xbox Slim controller now my new xbox slim controller will not connect to my new Xbox? It was working fine before my friend...
Hmmm.....that's sounds weird. The controllers are passive devices. They shouldn't change as far as hardware behavior because they're just that - hardware. Unless the one you have has some sort of CMOS programmable feature? I've never heard of that before. The only recommendation I have is to check the pins on the plug - maybe the old xBox damaged a pin.
Feb 05, 2011 | Microsoft Video Game Consoles & Games
Game loads okay but controller does not work. controller is brand new. lights work on controller but can not ply any games
If the controller is brand new, you need to Sync it with your XBox 360.
Turn on your 360 using the button on the console.
Turn on the controller by holding the X button in the middle.
With both on, click the SYNC button on the xbox 360.
Then click the SYNC button on the Controller.
The green ring around both should flash a few times, then the upper left quadrant should light up on both meaning it's Sync'd.
Enjoy.
Mar 17, 2010 | Microsoft Xbox 360 Wireless Controller
My xbox360 controller acts like its attempting to sync and then does nothing but blink on both ends I just hooked it back up for the first time in a year or so..When i attempted to sync the controller the...
I had a similar issue with the XBOX 360 Wireless controller. It blinked slow when it was turned on and when synced, the XBOX got the signal, the controller got the signal, but after the full flashes of both, the console ring stayed dark and the controller kept on blinking.
I managed to get it connected by powering the console on using the "XBOX" button on the controller and then pressed the connect button just as the console was opening up the user interface, apparently the console is looking for controllers when it's just getting up and running and syncs better at that point.
Hope this helped!
Sep 20, 2009 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
