Question about Uniden BCD996T Base Scanner
I need to program my bcd996t police scanner. - Uniden BCD996T Base Scanner
Try downloading something called FREESCAN. It works for the BCT15, BCD996T, and a few others. Its works great and its almost idiot proof. Its free software that works very well with radioreference.com. It programs itself.
Posted on Oct 03, 2008
  • 659 Answers
I have uploaded a pdf format manual for you if you do not have this.
http://files.hpifdesigns.com/pdf/bcd996Tom.pdf
also I hear there is a cd that comes with it too this might be handy to locate as well.
if you are wanting police frequencies please do a search for them on google.com eg. "las vegas police frequencies" ect and you should find alot of codes for your area.
Posted on Aug 02, 2008
  • 3 Answers
Read your manual carefully, slowly and repeatedly. Miracles don't happen over night.
Posted on Feb 15, 2009
2 Suggested Answers
  • 99 Answers
SOURCE: programming software not working with bcd996t.
You will need to update the firmware. Go here for what you need.
http://info.uniden.com/twiki/bin/view/UnidenMan4/BCD996TFirmwareUpdate
Posted on Aug 31, 2010
I need to delete one frequency at a time from a uniden BCD996T scanner.
it scan run all nuber threw all exct there 3 numbers wont scan it like there stuck they wont move at all then weather radio come on and it turend off
t
Feb 24, 2014 | Uniden BCD996T Base Scanner
How to edit a frequency on a bcd996t
if you don't have the manual, go to the UNiden site and download a copy
Sep 12, 2012 | Uniden BCD996T Base Scanner
How do i program the bcd996t from radio reference into the scanner.
You must have an appropriate software program to transfer directly from Radio Reference. As far as I know, the BUTEL 996 package is the only one available to do this. You can find more information here:
http://www.butel.nl/products/bc996/bcd996.html
or there's a link to them on the Radio Reference site.
I've been using their software with my BCD996XT for over a year, and it's fantastic!
Bill B.
Listening in since the 60's
May 09, 2011 | Uniden BCD996T Base Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
No clue how to program the scanner !!
Your best choice for software is the BuTel program. You can find it on Butel.com, ScannerWorld.com, or RadioReference.com. Once you have it installed you can download and program both conventional and trunked systems directly from RadioReference.com. I have the BCD996XT with Butel and RadioReference, and the combination works great.
Bill B
Apr 20, 2010 | Uniden BCD996T Base Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Unable to program trunking after uniden download was completed
I would try redownloading and reflashing the firmware on the scanner. If this doesn't work, you may want to try downgrading to the previous version of the firmware. If you are unable to redownload the firmware from Uniden, there is a Yahoogroup dedicated to this radio.
http://groups.yahoo.com/group/BCD996T/join
Also in the files section, there are older versions of the firmware.
Hope this helps!
Feb 10, 2010 | Uniden BCD996T Base Scanner
Uniden BCD996t
I went through the manual page by page and found no info on how to doa complete system reset.You might join the BCD996T Yahoo user group and ask your question there or look through this easier to use guide I found on the internet.(http://marksscanners.com/996/996.html)
May 07, 2008 | Uniden BCD996T Base Scanner
Uniden BCD996T Base Scanner Logo
288 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
