I need a manual to help set a tork ewz 201 timer
SRF518
  • 232 Answers
SOURCE: I need an instruction manual for the Tork 1101
go here:
http://www.weisd.com/store2/TOR1101.php
click on the wiring diagram
Posted on Oct 14, 2009
  • 15 Answers
SOURCE: I have a Tork dzm200bp timer and do not have
http://www.tork.com/pdfs/tork/ssamoreinfo.pdf
or
http://www.tork.com/tork/productdetail.aspx
Posted on Nov 06, 2009
SOURCE: I need an instruction manual for programing a Tork
http://waterheatertimer.org/pdf/TORK.DG100.120.INSTALL&OP.pdf
Tork DG100 7-day single channel digital controller
125 Volt clock motor
NC and NO poles
Posted on Oct 13, 2010
SOURCE: Tork timer "time clock motor"kaput...someone set
You posted under Tork 8601 timer:
I don't think that clock motor is sold separately.
New timer costs 115 at Chapman:
http://shop.chapmanelectric.com/tork-8601-minute-120v-spdt-p-2361-l-en.html
120Volt Tork clock motor that fits some models is sold at frontier for $43:
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
Usually the clock motor is held with 2 screws and then wires attach to screw terminals.
Look close at your screw terminals to see clock wires.
Normally timer mechanism snaps out of box and clock motor is on back of mechanism.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 25, 2011
SOURCE: i need instructions on how
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Posted on Feb 08, 2011
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 27, 2013 | Hardware & Accessories
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
2) Tork TU universal
http://waterheatertimer.org/How-to-set-timers.html
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
Feb 20, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
How to set tork outdoor timer model no.sa0022
Timer is not identified.
1) Copy following links to help identify SA0022 timer:
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
2) Add comment and describe timer in exact detail so expert can possibly identify same-similar manual
Dec 02, 2012 | Hardware & Accessories
Tork 1104 240Volt timer with #201 clock motor, uses P47 trippers.
Replace P47 trippers.
Order online.
Or Home Depot sell Jasco 15602 tripper identical to P69, located in timer department hanging on sales hook.
Nov 02, 2012 | TORK Variable Cycling Timer 8601
How to wire up a tork time clock 1104. 277v. Where does neutral go
277Volts with 1 Hot and 1 Neutral.
Tork 1104 #201 clock motor rated for 208-277Volt
http://waterheatertimer.org/Tork-timers-and-manuals.html#1104
Oct 10, 2012 | Hardware & Accessories
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
Jun 17, 2012 | Hardware & Accessories
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Computers & Internet Logo
132 people viewed this question
Alun Cox
David Payne
David Payne
