Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Ice collecting on bottom of freezer 1/4 in. or so...
  • 42 Answers
It sound like you have a frozen drain line. You have to go in from the front of the freezer and take the evaporator panel of to defrost the drain. Check to see if there is some food particles in the drain.
Posted on Mar 20, 2011
Why does ice collect at bottom of freezer?
The freezer has the only coil in the unit that gets cold. IT does build up with ice. The unit has a defrost heater that comes on to melt the ice. The water from this process is supposed to drain down a tube into the bottom pan that you cannot se under the unit. IF the tube is plugged with ice or other debris, the water from the defrost cycle cannot drain correctly and runs into the bottom of the freezer. There is quit a bit of work involved in getting this to work again.
Jul 18, 2014 | Whirlpool Refrigerators
My freezer part of the refrigerator collecting ice in bottom shelf
Is it collection frost on the back and bottom shelf or is it ice on the very bottom of the fridge?
Aug 17, 2010 | Maytag Refrigerators
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pooling underneath bottom drawers
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Top freezer develops ice on left bottom side.
it has to be connected other wise its true that ice will get collected.because the compressor will give its coldness in refrigerator so the cold air of freezer will also get collected in refrigerator side, because there is no ice dispenser connected.connect the icedispenser.
to make it proper.
Apr 01, 2009 | LG Refrigerators
Water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
