Where can I buy a new duo therm heat pump model # 59516.531 for my 2007 montana
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
motor1258
  • 6674 Answers
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Posted on Aug 14, 2008
carlsbiz
  • 1124 Answers
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Posted on Jul 09, 2009
motor1258
  • 6674 Answers
SOURCE: AC won't run on low speed
It may not be wired for low & high fan mode. If it always did before, then yes there's a problem.
Posted on Jul 19, 2009
  • 46 Answers
SOURCE: Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Posted on Aug 01, 2009
I have a duo therm model 630035.321. What is the best replacement unit?
There isn't one. Every a/c unit is a piece of junk. Just like your t.v., fridge, and microwave. Buy cheap, replace when it breaks down. It's all luck, so Good Luck!! Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 04, 2017 | Dometic Heating & Cooling
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
