Question about Logitech Z-2300 Computer Speakers
Where does the thin, small wire from the volume control panel connect to? It has been pulled and ripped out and I cant figure out where it goes. Where can I go get it fixed?
    Sergeant:
    Champion:
  • 286 Answers
If you know anything about electronics. It could be an earth lead. If not, try PC world or your local computer dealer. Hope this helps.
Posted on Apr 07, 2011
Tip
Wiring For Volume and Power Switch
I ripped the cord off the external thing-a-ma-bob for the volume and power switch on the Maxell Flat Speakers with Subwoofer unit, but managed to figure out which color wires attach to each numbered contact on the small circuit board inside the unit. The board has labeled contacts from 1 through 9, and following is the map for each color wire:
1 = Black (large wire, ground)  2 = Red 3 = Brown 4 = Orange 5 = Yellow 6 = Green 7 = Blue 8 = White 9 = Black (small wire)
I resoldered each wire back to the little board and it works like new. Much better than throwing them out and getting new ones, because these speakers have a decent sound and take up very little room.
I hope this helps anyone who runs into the same situation, because I was unable to find this information anywhere else and had to figure it out by trial and error.
on Sep 04, 2008 | Maxell Flat Speakers With Subwoofer and...
I have to get the panel off to get to the wires. The lighter came out and the wires are in this hole. how do I remove the panel?
General practice:Better use a lantern and a hook to pull the wires.If not,usually,under the clima controls knobs (pull out by little force),must have screws /clips to take out.If clima control is separeted by main,still may gain acces to wiring.The panel (s) needs side help to pop,do not use sharp/hard tools,plastic soft are better to avoid scratches.Many cars need to take the radio out also,this have side locking (ceck the small holes on sides,need a unlocking long thin tool)or by using a flat tool to unlock the pins by sides.Sometimes the panel (s) have taped (hidden) screw easily identyfing by close visual inspection.If the lighter has it's own painel u may need to pop this one out (like opening a phone).Inspect carefully and gently pull the sides with a plastic tool till figure out the removing sequence.U may put your finger in the hole to help it pup.U also may need to figure out how the lighter became loose.Watch for the corect wiring plugs.All advices are for general good practice,not for a specific car.Cheers.
Oct 26, 2013 | 2006 Chrysler Sebring
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
Hotpoint Washing Machine Door Interlock (how to wire up)? I have removed the old door interlock and forgot to make a note of where the wires go, (wont make that mistake again) I have 3 wires White Brown...
The three wires you should have are
1-Brown-goes to L
2 Thin black to N
3 White to C..
Hotpoint never have incorporated a wiring diagram on any of their british made appliances, so previous comments made do not apply in this case.
Hope this helps.
Jan 03, 2010 | Washing Machines
How to replace driver side window 97 4 door honda civic
normally on the honda2.gif models there are two screws that need to be taken out, the inside latch area (plastic cap covering it) and the door pull (normally down in the bottom covered with a plastic cap), thin small flat blade will work to remove. once the is done you will need to pull out the latch area on the driver's window control panel, disconnect the connectors. set the aside, next you will need a thin flat blade screw driver or flat pry bay, start at the bottom of the door to pry out the panel, check for screws, if you cannot see any proceed to using the flat blade to remove the panel (will make a loud snapping or popping noise, this is normal) once you have loosened the panel, you will need to remove the plastic covering the access to the mirror (small triangle black plastic piece). this should now allow you to set the door panel aside, check to make sure you have removed all the clips. carefully remove the plastic lining cover the door, try not to tear or rip it. now you will need to remove the glass, there are two holes the allow access to the bolts for the window, connect your Power window switch and raise or lower till you can see them ( possibly a 10 mm socket) unscrew and set aside, hold the top of the window with one hand and lower the window to separate it form the brace. tilt the front side of the window down and remove glass set aside, replace your new window and re assemble as you have taken apart, most cases this is about two hours, Good Luck !!!
Jul 07, 2009 | 1997 Honda Civic
Toshiba tv 32ax60 3 thin wires disconnected
belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Dec 02, 2008 | Toshiba CX36H60 TV
Where is the Fuse??
once you take off the back of the tv you can see where the power cord plugs in and there is a thin metal cover you pull that off and unplug the power cord from the board and right in front of that under the other metal cover you will see a small fuse with a white middle. pull it uot and get a new one. i think that is what you are looking for
Aug 19, 2008 | Protron PLTV-32 Television
Logitech Z-2300 Computer Speakers Logo
15 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
