Question about Canon PowerShot SX100 IS Digital Camera
Changing Movie Recording Pixels
Good day.
I am trying to reset my movie recording pixels to standard, as some how it accidentally got changed to compact. The manual says change to movie setting, hit Func set, the use up/down arrows to choose the pixel setting in the bottom left of the screen. Unfortunately, the up/down arrows won't move the curser down to the pixel setting. It only allows me to change the first 2 menu items. Why won't it let me move the curser down to the pixel number as the user guide shows?
Thanks,
Don McCall
  • Anonymous Aug 26, 2008
    Like the original poster, I followed the manual, but the 'tab' to select the resolution is not selectable.
  • Pikerdon Sep 24, 2008
    Yes, for me too. Thanks!
Thanks, that worked.
Posted on Sep 15, 2008
I phoned canon customer service. They said that you must turn the dial around the function set key. It will then change the movie mode from compact to standard ... and then you will be able to change the resolution. When I did it, the resolution went back to 640, which is the resolution on which I had it previously. Well before the compact mode issue.
Yannick Jeggels
Posted on Aug 26, 2008
What does fsh, gfs mean
It may mean you need to buy a vowel? Sorry, I know that's not helpful. These are codes for HD recording modes.
" HD Movie Recording 1920 x 1080 pixels, 50i (Sensor output is 25p) (FSH: 17Mbps, GFS: 17Mbps / AVCHD) 1280 x 720 pixels, 50p (Sensor output is 25p) (GS: 17Mbps, SH: 17Mbps / AVCHD) 1280 x 720 pixels, 30 fps (QuickTime Motion JPEG)"
Jul 28, 2012 | Panasonic Lumix Dmc-ft3 Waterproof Digital...
Got Fuji digital camera 12 mega pixels AV 110 dont know how to record video, what type of battery to use now bought new eveready Battery when it switched on immediatly is get off. Kinldy help me
To record video: Press Menu/OK, select Shooting Mode, select Movie, press Menu/OK.
Press the release button to start recording, press it again to stop.
For digital cameras it's recommended to use Ni-Mh batteries. Buy some with good capacity +2500 mAh or better.
Oct 22, 2010 | Fuji Cameras
I can't record more then 20 sec video file
I'm sorry to inform you but after researching your camera only records for 20 seconds. It has nothing to do with your card. Only 20 second blocks of time.
Movie mode - The total amount of recording time available is shown by the green "00:20" in the lower right hand corner. This is SHQ 640x480 resolution at 30fps, the maximum recording time is 20 seconds. In the lower quality 640x480 @ 15fps or 320x240 size, the recording time is limited only by space on your xD card. The shaking hand icon indicates that we have the image stabilizer turned on.
Oct 04, 2009 | Olympus SP-560 UZ Digital Camera
Problem with Pixelview TV Tuner
I have a PixelView play tv pro3 tv tuner,2.4 hz p4 pc with 512 ram and creative 4.1(4400)speaker with cmedia audio drivers also k lite codec installed.My pc have two audio connecton. I connected audio properly but i cannot hear sound when i played recorded file.i used pixelview soft.also used windvdr also try changing the audio wires also changing settings in control panel also reinstall xp but the problem remains.please help me.
Nov 28, 2008 | Prolink PixelView PlayTVpro Video Capture
Video
Lizzie,
This may sound like a dumb question, but are you sure that you had the camera set to the video recording mode? Several of the Canon digital PowerShots will show the movie icon on the LCD screen even when the camera is in image record mode. Why, I don't know. Ensure that you set the camera into movie mode by pressing your Func/Set button to go into the Function Menu and then selecting the movie mode that you want to shoot in. Press the Func/Set button again to get out of the Function Menu and you will not only see a movie camera icon on the LCD screen, but also a set of numbers in the bottom left hand corner representing the recording resolution (e.g. 640 pixels) and the frames per second (e.g. 30).
And just in case you did have the camera set in movie mode, make sure that you don't do what many people have inadvertantly done and mistake the video clip for a .jpg image in the playback screen. Videos will of course have the movie camera icon in the upper corner of the image and are viewed by pressing the Set button twice to begin the playback.
If both of these steps were performed properly then your camera may have a hardware issue. As a last resort, try performing a reset from within the menu just to be on the safe side and see if it makes a difference. If not you may need service. Hope this helps.
Sincerely,
HeavyDLB
May 26, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Can't change settings on movie option
To change movie resolution:
1. Set control dial to movie mode
2. Press the Func/Set button
3. Scroll down to the recording pixels icon (probably 320 on yours right now)
4. Use left/right arrow to select 640
5. Press Func/Set button
May 23, 2008 | Canon PowerShot G7 Digital Camera
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
What are the main features of DiMAGE A2?
It has succeeded from A1's concepts, "Providing the more enhanced image quality," "Reducing the mis-recording," "Not limiting its users or scenes" and "Providing the unexpected satisfaction, pleasure and impression" from the DiMAGE A1. Compared with A1, it is the all-in-one type digital camera achieving not only the still image but the high quality of viewfinder and movie. - 2/3 type interlace scanning CCD with primary color filter and 8 million pixels - VGA-size with a high precision EVF (922,000 pixels) is loaded to check the focus more easily. Compared with A1's EVF, about four times the high precision display is enabled (A1: 235,000 pixels). - Depth-of-field preview - Movie recording function of 544x408 size with 30fps - USB 2.0 support (high speed mode) which can transmit large data in high speed - PictBridge support Furthermore, 3D AF to track the movement and keep focus on the subject and anti-shake compensation functions inherited from A1 are also loaded.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
