Question about Garden
How do you remove the probe on a Paslode angled finish nail gun, gas operated! the manual tells you to remove if bent but don't tell you how! I turned the flush deep adjustment wheel and it still don't come off, what do you do to remove this bent probe.
  • 104 Answers
SOURCE: paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Posted on Oct 22, 2008
  • 24 Answers
SOURCE: Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
Posted on Apr 14, 2009
comax
  • 154 Answers
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Posted on Jun 11, 2009
  • 14 Answers
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Posted on Aug 04, 2009
  • 128 Answers
SOURCE: Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Posted on Feb 19, 2010
Tip
Paslode Cordless Nailer Problems
<p><b><i>Paslode cordless nailers</i></b> are a very common tool used by many professionals and do it yourselfers. These <b>nail guns are a great tool</b> when they work correctly, but can drive you nuts when they do not work as they should. When answering problems that people have on <a href="http://www.fixya.com/"><b>www.Fixya.com</b></a> I come across many questions about these nail guns and why they do not work.<br /> <p><br /> <p>If you are having problems with your <b>Paslode nail gun</b> the first thing you need to do is get the <b>Paslode manual</b> out of the box and checkout how to <b>clean the nail gun</b>. One of the most common causes for these <b>nail guns to have problems</b> is because of a<b> lack of maintenance</b>. If you do not have the <b>manual for your Paslode nailer</b> you can download one here. <a href="http://www.paslode.com/owners-manuals.html">www.paslode.com/owners-manuals.html</a><br /> <p>They have all of the current models and also <b>discontinued model Paslode manuals</b> there.<br /> <p><br /> <p>The manual will also contain <b>troubleshooting information</b> also. The <b>troubleshooting guide</b> can often help you to find the problem with your tool. Do not do the common man thing and be too proud to <b>get out the directions and READ them.</b> There are many tips and helps contained in them that will save you a ton of aggravation later.<br /> <p><br /> <p>Now, there are a few things that I have found out through my experiences with this nail gun that are not in the manual. <br /> <p><br /> <p>First, When the manual tells you that the tool needs to be <b>cleaned and lubed regularly</b> it means that you NEED to do that. Most problems are because of a<b> lack of cleaning and lubing the tool</b>.<br /> <p><br /> <p>Besides that, <b>gas cylinders</b> are a problem sometimes even if they are new. If you just replaced the gas cylinder and the <b>nail gun will not work</b>, try another one. Also, sometimes the end that goes on the gas cylinders will not snap on correctly or completely. You sometimes can still get the cylinder into the gun but it will not work because the top is not attached completely or correctly.<br /> <p><br /> <p>Check that the <b>nails do not get jammed in the magazine</b> and then not push up to the front of the gun. No nails, no work. Paper from the nails can sometimes cause them to bind up and not slide front. Make sure to always use nails that are only for the<b> Paslode nail gun</b>.<br /> <p><br /> <p>The firing pin can also be a problem. The <b>firing pin will bend</b> sometimes, but usually because of lack of the right nails or maintenance. Another problem that can happen is that the<b> o-rings around the firing pin</b> will break or crack. When this happens the gun may not fire or the pin will not return after it shoots a nail. If you are having these problems then check the o-rings both top and mid-pin to make sure they are in good shape. If they are chipped or cracked in anyway the gun will not work correctly.<br /> <p><br /> <p>The <b>battery contacts</b> on these nailers are also a problem. They can get dirt and dust in them or become bent. If they fail to make good contact they can cause the gun to have all types of problems. If you are having unexplained problems then<b> check the contacts of both the battery</b> and the gun. You can clean them with a soft cloth or sometimes with a pencil eraser.<br /> <p><br /> <p>The last but least likely problem is the<b> internal wiring in the nail gun</b>. Because of the violent nature of the gun firing the wiring takes a beating inside the nail gun.<b> Every time the gun fires</b> the vibration can cause the wires to move just a bit and eventually a wire can work loose. If all other things check out then look for wires that do not go anywhere. If there is a wire floating around that has no home then you have found your problem. After adjusting the end of the wire so it is tighter, reconnect the wire and you will be working again.<br /> <p><br /> <p>As you can see there are many things that can go wrong with these nail guns. Because of this there also are many things that you can find online that will help you. <b>E-how.com</b> has some tips that will help. <b>You-tube</b> also has some videos that will show you how to clean and troubleshoot these nail guns. Doing a simple online search will give you many places that can help you and also give you sites from which to buy parts if needed.<br /> <p><br /> <p>If you need parts for your nail gun, here is a good place to get those parts.<br /> <p><br /> <p><a href="http://itwconstructionparts.com/xcart/">http://itwconstructionparts.com/xcart/</a><br /> <p><br /> <p>
on Mar 06, 2011 | Tools & Hardware - Others
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
Were can i buy a instruction manual for a paslode
go to Paslode.com and you can download the manual for free. Let me know if you have any problems
Dec 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Gun not firing batt charge, new gas, fan goes just not firing
could be a couple things, first are there nails in the magazine, this tool has a stop when low on nails it won't fire, second is the lower probe bent not allowing full push on the cylinder to load gas. Give me the model number and I will find a print or you can go to Paslode.com and type in the model number and get an owners manual that has a trouble shooting guide in it for help. Let me know and if I have helped you with your question would you please rate this response accordingly.
Sep 05, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Mar 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
