Question about Marin Quake 7.8
I have a marin quake 7.3 xlt and am running the 150mm maxle dropouts. when stationary if i push sideways on the rear wheel there is a clicking noise , this noise also happens when i turn corners hard and when i first start pedalling. Any quesses what this noise is?
    Guru:
  • 347 Answers
A few possible guesses.
1) the hub is loose and needs to be adjusted
2) the Freehub is loose and needs to be adjusted
3) the wheel is not securely in the frame
4) all these things
5) something inside the hub or hub assembly is broken
Solution: for all these take the bike into your local shop and have them take a look.
There is one other possibility, your spokes are not at full tension and the spokes are clicking against each other when you put enough lateral force on them. Again you want the shop to retension the wheel.
Depending on the wheels you have you will either need special tools to fix, parts, or special knowledge or all these. So better to pass on to a shop that has some experience working with this type of bicycle and get it done right once.
Posted on Mar 20, 2011
I have a moto guzzi sport 1100 1996.No oil leaks from rear wheel when standing but spots of oil on wheel and tyre after riding a few miles.Any help would be appreciated
oil leaks during use indicate a loose bearing adjustment allowing the oil to move past the seal lip when rotating
I would be checking wheel bearing condition and adjustment, oil level in that section and wear groove for where the oil seal lip runs
reasoning is , when the wheel is stationary the oil is not being splashed around and will settle in the lowest places
when moving , if the seal housing is allowed to move separate to the axle position ( wobble , up down sideways etc) then small gaps appear between the seal lip and what it runs on and so oil is allowed to escape
if it is a drive shaft to the rear wheel check the output shaft to the wheel for movement ( bad bearings , adjustment/ preload ) or anything that will not keep the shaft in the center of the seal
Nov 19, 2016 | Moto Guzzi Motorcycles
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Jan 05, 2016 | Ford Cars & Trucks
Whirring noise from mitsubishi dion
Sounds like you have a defective wheel bearing.
Jun 07, 2013 | Mitsubishi Mirage Cars & Trucks
I have just bought a new SCHWINN CORONADO WOMAN BIKE and i'm trying to assemble it. The distance between the fork dropoouts is bigger than the front wheel axis. The only possible assembly of the front...
When you tighten the quick-release skewer, the two sides of the fork will be pushed inwards over the axle. So basically, just tighten it up & it should be just fine. If not- take it back to the store you got it from!
Oct 30, 2011 | Schwinn Coronado Women's 26" Alloy Frame...
Trying to fit Tioga alloy carrier to mountain bike and it doesnt appear wide enough to pick up bottom points.What or where are the rear dropout points?
The "rear dropout" points are the part that connects the rear axel to the frame of the Bike. You likely have to remove the back wheel during the process of installing it.
Feb 28, 2011 | Cycling
There's a whinning noise towards the back right of the car is this the fuel pump?
If you can hear it outside the car running while stationary then yes. If the noise occurs when moving then no, probably a rear wheel bearing.
Jan 29, 2011 | 1984 Volkswagen Rabbit
I hv a '01 Aurora w/ 105000miles. On choppy pavement, the rear tends to skip sideways w/assoc knocking noises like worn or loose struts. Left rear tire on outside shows more wear than the other three....
This is related to the "link assy" parts on the rear end. They are about 30" long. One end bolts near the center of the car. The other ends have a tie-rod type end and mount to the rear wheel assembly.
The knocking noises are because the link assy are bad. About $70.00 each for these. I would also check the upper shock mounts on the rear. These go bad and will cause noise as well. About $15.00/ea. Easy to replace.
The skip sideways is because the link assy or rear alignment is off. This is easily fixed and should be done as soon as the parts are replaced.
Oct 04, 2010 | 2001 Oldsmobile Aurora
2005 Ford Expedition XLT, major electrical problems
You have a wiring harness problem
Take it to the dealer directly.......
Nov 18, 2008 | 2005 Ford Expedition
Marin Quake 7.8 Logo
187 people viewed this question
Top Marin Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Marin Cycling Expert? Answer questions, earn points and help others
