Question about Saniflo Home
Hi I have a saniflo compact which won't flush on the first press of the button - it takes several goes. Can anybody advice.?
  • 528 Answers
Replace the the button switch it has or is going bad. You can try taking it out and cleaning the contacts but this hardy ever works.
Posted on Mar 21, 2011
Can the flush mechanism be moved to an external site
Well now, that depends on your ingenuity.
If you can exactly duplicate the action of the flush handle, of course you can move it anywhere you please.
I am at a railroad museum, and railroads could move track switch lever mechanisms several hundred feet away from the switch, it just takes imagination and precision.
Saniflo will not be able to help you, but an inventor might be delighted to do so.
God bless your efforts.
Dec 15, 2015 | Saniflo Home
Saniflo toilet needs more than one flush to clear the bowl from toilet paper etc.
If it is going out slowly, get large containers of hot water and flush until it goes out faster. It may take several containers but hot water works wonders and doesn't cost much.
Jan 22, 2015 | Saniflo Home
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
Our saniflo system works ok, its just when left idle, the pump seams to start up every 40 secs. I've flushed it and held up the ball **** and it stills does it. Any ideas?
One thing to check is the check valve may be leaking back, float may be faulty, toilet maye be leaking and filling tank causing pump to come on.
Check out this link with a trouble shooting guide for this unit.
This first kink has information on different types of Santiflo systems.
http://www.saniflo.com/Downloads.aspx
This next link has a trouble shooting guide that covers these issues.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Jun 24, 2010 | Saniflo & Saniplus& Macerator Pump
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
I fitted a saniflo plus about 3 months ago engineer been out 5 times even changed unit last engineer said it was toilet paper stuck in tiny hole at bottom of motor he said it was due to not flushing...
This could be a problem with the capacitor which drives the blade and impeller. If it goes bad it will pump water only but when solids are flushed, it will jam the blade and cause it not to spin. You may have to replace the capacitor/condenser.
Nov 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniflo system and need to know how to unblock it
check the fuse has not gone or the trip for the electrics before proceeding as no power = no saniflo, assuming this is ok -
1. get old rags/papers and some rubber gloves (marigold type), plastic beaker and a bucket.
2. get a pozi and a flat screwdriver
3. isolate electric supply to saniflo
4. ensure loo cannot be flushed (tape handle)
5. place cloths and papers around pan
6. bail water from pan into bucket (as low as poss) with beaker
7. slacken screw to pipe on top of saniflo (outlet)
8. get bucket (now emptied) disconnect pipe and prepare to catch liquid from pipe, especially if pipe goes up the wall.
9. slip connector off pan, depending on model there may also be a connection from a sink / shower / bath to disconnect.
10 attempt to withdraw saniflo from behind pan - if this is not possible you will have to remove the pan.
11. remove top from saniflo (screws around lid)
12 when the top has been removed you will see a basket inside, if the blockage is from a female article (of the cotton wool nature) this will be jamming the motor and pump, remove any problems (sometimes a loo fresh thingy) take care as there are masserator blades at the bottom of the basket.
13 if the basket is clear and you can see the blades it is a unit failure - it is often cheaper to buy a new one than pay for a service engineer, check first.
14 if you can remove the blockage then do so - re-instatement is the reverse of removal.
If in any doubt seek professional advice, if you get stuck seek professional advice, do not reconect electrics unless you are sure everything went ok, do not reconnect electrics sitting on damp floor, best leave everything to dry out before reconnecting and trying it out
Oct 21, 2009 | Saniflo SaniPlus-Elongated SaniPlus...
Home Logo
240 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
