Question about Thermador C302U Electric Double Oven
F7 and beeping - Thermador C302U Electric Double Oven
Oven starts to beep and shuts off. I shut the circuit breaker off and it re sets itself and hopefully when I power it up it will start to work. We have replaced the front panel and all th PC boards and reset the reset button behind the panel. If there was a was that I could disconnect the shut off that's built in I would keep the oven.
When this oven work, it's great however at this time i am losing patience and maybe I should toss it out and get a new oven which I really don't want to do!
I am very capable of taking it out and opening up the panel an re setting all the boards once again if that would help? Thermador has had a recall on this unit as some people claim it will overheat and go on fire? The stove has little mileage on it and we would like to keep it but if you have a way of fixing it or if not we would love to hear from you! .
Posted on Apr 05, 2011
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Jul 25, 2008 | DCS WO-130 Stainless Steel Electric Single...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
Thermador C302U Electric Double Oven Logo
210 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
