Question about Blueair 501 Air Purifier
Where can I get replacement wheels for a BlueAir 501 air purifier?
2 Suggested Answers
SOURCE: My blueair 501 suddenly stopped working. I turned
Yes, there is a fuse. No idea how much risk there is in accessing it, as my knowledge of the model is based on taking mine apart... and mine still dosn't work. If you unscrew 2 of the four screws, the side will slide up (the other two are for the other side), you can peer in and see the fuse.
Posted on Sep 09, 2010
What size is the fuse on the Blueair purifier.
Hi there.
15 amp. Also remember there is a reason why the fuse is not working. Goodluck ..
Sep 23, 2017 | Blueair Air Purifiers
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
Blueair 301 Air Purifier Owners Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Blueair model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/blueair/301.html
You can purchase a wide variety of high quality Blueair replacement parts for your Blueair Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Blueair
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 21, 2013 | Blueair 301 Air Purifier
Dust caked up on wires and fan,how do you take it apart to clean it?
This question seems similar to another post from a while ago. http://www.fixya.com/support/t5074178-like_clean I just finished my Blue Air 500 for the same problem with loads of collected hair and dust around the fan. The manufacturer manual does not cover this type of cleaning and they do not want people to open the unit as it might void the warranty. It's actually simple you've done it but not obvious. There are 4 screws which you may not have seen on the top until you pop off the top grill. Remove those as they fasten the side curved panels, once the top screws are removed tug on the white curved pieces upwards and they should come off. Once these are off you should have full access to the interior to clean. Ours was utterly filthy and way past the warranty.
Feb 28, 2011 | Blueair 501 Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
Jun 05, 2009 | Blueair 501 Air Purifier
RED CHANGE FILTER LIGHT DOESN'T GO OUT AFTER CHANGING FILTER
I had the same issue.  Press and hold the 'TIMER' button untill you hear a beep and it will reset.
Apr 02, 2009 | Blueair 250E Air Purifier
Car dieing
You may have a Vacuum Leak, Throttle Position Sensor may be bad, and the MAP Sensor. Those are know to go on the 3.1L Chevy Lumina's. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Good Luck.
Jun 30, 2008 | Blueair Blue Air 402 Smokestop Particle...
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Dec 28, 2007 | Blueair Blue Air 402 Smokestop Particle...
Blueair 501 Air Purifier Logo
47 people viewed this question
Top Blueair Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Blueair Air Purifier Expert? Answer questions, earn points and help others
