Question about Whirlpool Kitchen Ranges
SELF CLEANER NOT WORKING FSE1 CAME ON - Whirlpool Kitchen Ranges
  • Whirlpool Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Mar 20, 2011
Whirlpool gas range self-clean cycle produces FSE1 on display and door doesn't lock, audible alarm sounds
I found this on an appliance forum. It sounds the same as your problem. They say the code is F5 E1. Apparently the door lock latch is stuck.
Appliance Repair Forums
Dec 30, 2014 | Whirlpool Kitchen Ranges
FSE1 CODE just popped up on the stove and the latch started going back and forth and the interior light would go on and off. We weren't even using the stove or oven when this happened. What does
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Dec 10, 2012 | Whirlpool GR460 Electric Kitchen Range
KITCHENAID OVEN MODEL KEMS 308 SELF CLEANING
Hi David.
The error is F5E1 and means door latch problem detected. This happened in consequence of the power cut while the unit was in self clean.
Try pressing and holding down the cancel button for one minute.
Try disconnecting power from circuit breaker for ten minutes, that will reset the control board.
If that does not work the door latch, wiring and control module must be tested and the defective part replaced.
Here full troubleshooting from Kitchenaid service papers:
1. If the door lock is latched:
  1. Disconnect power.
  2. Check wiring and connectors from control module to door switch, then from door switch to control (do a continuity test). If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace the door switch.
  4. Re-apply power.
  5. Press and hold down any key down for 1 minute to clear the F5 failure code from memory. F2 will appear. Press CANCEL and wait one minute.
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps 1 and 2 for the door switch.
3. Measure door switch (door open =switch open - Ohms infinity/small low voltage terminals depending on test done- Ohms reading is done with power off). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If the problem remains, disconnect power and replace control module.
Regards.
Ginko
Jan 01, 2012 | Ovens
Fse1 shows meaning? Want to clean
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 15, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 | Ovens
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
heatman101
Jan 19, 2011 | Whirlpool Ovens
Self cleaning oven function does not work. display shows fse1 meassage
heatman101
Sep 05, 2010 | Whirlpool Kitchen Ranges
Oven beeping and says FSE1
Door Latch Switch look here.......http://en.allexperts.com/q/Major-Appliances-3603/whirlpool-oven-fse1.htm
If I can't find it on the internet, it's because it isn't there!...Linda
Jul 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
Code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
6. If failure remains, disconnect power and replace control.
Apr 01, 2009 | Ovens
Kitchen Ranges Logo
347 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
