Question about Ultimate Sound Ultimate Bicycle Support Pro Ultralight Repair Stand
The "jaw" of the bicycle
    Guru:
  • 347 Answers
All answers for Ultimate stands can be found at their website here. They have excellent customer service and manuals on-line at the links, etc...
Posted on Mar 20, 2011
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Mar 23, 2014 | Electric Bicycle Motor, Bike,electric...
How do I reattatch the right rear brake on my k2 cheyenne bike? It just fell off!
from the frame or the pads? if it fell from the frame then you might need a new nut or maybe see a bicycle repair shop.
Sep 06, 2012 | K2 Cycling
M1112 chuck .0045 off center
There are three possiblities: 1. dirt interfering with the jaw position or between the jaw and the workpiece - if you loosen, tap the jaw, retighten on your work and the result is repeatable, then this is not the problem. 2. the jaw itself needs to be cut, as you are doing - this will solve the problem and give you repeatably centering so long as 1 or 3 are not the problem. 3. The most insidious problem would be that the spiral groove on the back plate which is supposed to move the three jaws in harmony has a bad spot - this would give you inconsistent centering of the jaws at different diameters and could only be fixed by re-grinding that spiral groove (this would be VERY tricky to do yourself) or replacing the backplate.
good luck!
Jun 13, 2012 | Shop Fox M1112 Gunsmith Metal Lathe 2 Hp...
I have to change the "rear chain adjusters" on a 2001 Honda XR100r. The left side is obvious (take off he axel nut and replace). But the right side is set in place under the main axel bolt. So I...
It is the axle bolt and it goes right through the wheel hub.
You will need to support the bike, as when this axle comes out , so will the wheel.
remove the axle nut and tap the axle out with a brass hammer, if it is corroded you may also need a brass drift slightly smaller than the axle to drive the axle out.
May 01, 2011 | Honda XR 100 Motard Motorcycles
Schwinn Scotch bike. Can't get the front wheel on. Have removed 1 nut and 1 washer from each side but the forks will not fit down onto the "screws" almost as if the forks are not set wide enough.
Stand the bike on seat and handlebars.
Have somebody steady the bike.
Bend the forks outward with both hands as you lower wheel into place.
Dec 25, 2010 | Cycling
Loose steering
there is a threaded collar and lock nut at the top of the steerer tube that extends from the front forks and connects them to the (head) tube at the front of the bike's frame. Tighten the collar, and then tighten the lock nut, and you should be fine. You will need either a large open wrench, or vise grips with a large jaw, or pliers that can slip from one size to another.
Nov 17, 2010 | Cycling
I have a hobart a-200 mixer that had the brass drive gear go out. I rebuilt the transmission and used a parts breakdown to clean out and rebuilt the whole tranny. Now I have no 1st gear. Under a load...
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
May 20, 2010 | Hobart A200 Stand Mixer
How to pump it with SCHWININ AIRDRIVER 1100
There are two styles of valves on bicycle inner tubes. The commonly used style is called Presta, and it is characterized by a thin, threaded brass stem with a head that has a threaded pin in it. This has a small nut pressed on that must be unscrewed to fill it with air. The other style (which resembles the valves on a car's tire) is called Schrader. Bicycle air pumps can handle both styles, but some require a reconfiguration of the pump's valve to make the change from one style to the other. This involves unscrewing the head and removing the parts inside. The details on these processes and the styles of valves on your bicycle will be found in the air pump manual.
Sep 07, 2009 | Cycling
Ultimate Sound Ultimate Bicycle Support Pro Ultralight Repair Stand Logo
293 people viewed this question
Top Ultimate Sound Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you an Ultimate Sound Cycling Expert? Answer questions, earn points and help others
