Question about Keurig B60 Coffee Maker
Handle is stuck...i'm afraid to pull too hard because it is made of plastic and I might break it....suggestions
    President:
  • 1,654 Answers
I Can give you instructions for dissasembly, but not sure how the handle is stuck or what caused it to stick.
First take the bottom metal plate(5 screws), you need to remove the plastic base plate then work on removing the black outer sleeve. Remove 4 screws and the 2 small screws at the bottom of the water inlet. This avoids cutting the ty-raps and removing the tubing. Now remove the plastic base plate and work on releasing the j-hooks with screw drivers from the outside off then take the black outer sleeve off. The black outer sleeve is held to the top silver part with 3 plastic j-hooks which are part of the top silver part to hook into plastic brackets on the black outer sleeves. The j-hooks are located at the back about 1 inch from the left side, then about 5.25 inches from the left edge around the curve part of the sleeve and the 3rd hook point is in the front about 1 inch from the right front corner of the sleeve. There were no screws holding the sleeve as tgmusicgirl indicated on my B50 unit. Releasing the j-hooks without breaking them are very difficult since it's plastic and you can't see them to release them properly. Once the j-hooks are released the black sleeve slides toward the bottom to remove it. One way to imagine the j-hooks is to think that the j-hooks are pointing down with the open end facing the sleeve. The sleeve has rectangular rings molded on the inside of the sleeve and you just push the sliver part down into the sleeve until the j-hooks snaps into place.
Posted on Mar 20, 2011
Hoover Spinvac F5915900. Trigger no longer causes a release of soapy water on floor. It doesn't have tension, fairly loose, but still in slots. How do I fix this problem?
The trigger that you pull to release water snaps into plastic pieces inside the handle where it pivots to push on the rod that goes down to push on the regulator that lets the water flow. If the trigger is pulled too hard it can break the plastic it pivots in. If this happens the rod doesn't push hard enough on the regulator to let the water flow. Remove the screw at the top of the handle to remove the handle part holding the trigger to see if this could be causing your problem.
Jan 28, 2017 | Hoover Vacuums
I have an erc turntable and the start button is stuck any suggestions
TBA - Shaun has posted a thank you to you for your help on this question -
http://www.fixya.com/answer/answerpageslideview.aspx?thid=26286607&ctg=514
Jul 23, 2016 | Audio Players & Recorders
The bin on my royal cross cut paper shredder will not open . It is full and needs to be emptied. It seems to be stuck near the top. If I pull any harder I am afraid the hard plastic will crack.
Yes it is probably "over-full".... you will just have to try to somehow get it open a little and start to fish out the paper without breaking the waste bin....it has to be emptied more frequently, there is no "bin-full" indicator.
Dec 28, 2010 | Royal Office Equipment & Supplies
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic...
I have the exact problem with my LG LHD45EL as lubbock51's Aug 17, 2010 question. (see below) Isn't there anyone out there that's had this same problem and resolved it. I too am afraid to pry the grill for fear of breaking it...it made out of plastic so it won't take much to break the grill if I did.
By lubbock51 on Aug 17, 2010
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic in fear of breaking it. Any suggestions?
Aug 17, 2010 | LG LHD45EL Dehumidifier
A client is finding it rather difficult to open the door to a gaggenau RC472 integrated fridge. The main problem is that in order to break the vacum seal, you have to pull the door very hard. Any...
not adjustable im afraid.have you thought of a lever that looks like a handle of a one arm bandit?? to lever open door (for old folks)
Mar 09, 2010 | Refrigerators
I have Delta Series 1400 Solid Handle and after taking the tension screw out I can't get the handle off. What do I need to do.
There is a set screw under the handle. You will need an allen wrench (hex head) to remove the set screw. Once you remove the set screw, use force to pull the handle away from the shower wall. If it feels stuck use some force alternating between pushing and pulling (rocking motion). I am including a picture in an exploded view so you can see how it assembles and disassembles for your convenience if you need it. Also if you need to replace any parts for the faucet, the part numbers are designated for easy replacement. I hope this helps and good luck!
Feb 20, 2010 | Delta & Single Handle Shower Faucet
Removing door panel on 1997 Hyundai Accent
Look under the round part of the handle,see if there is a small allen screw there,if it is unscrew it until the handle comes off.if not send a new message
Sep 06, 2009 | 1997 Hyundai Accent
Small stream on hot side of two handle kitchen
They can be tuff to pull up and out. Give it a wiggling action as you pull
Jul 10, 2009 | Plumbing
Fellowes C120-CShredder Full but I can't pull the plastic bin out
Yeah, you can take the top off.... My C-220 had three screws under the front top area, and then two snap-out tabs at the top back area. It was easy.
May 07, 2009 | Fellowes Powershred 120C-2 Shredder
Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
May 31, 2008 | Singer 5062 Mechanical Sewing Machine
Keurig B60 Coffee Maker Logo
475 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
