Question about Canon Cameras
My serial number is worn so much I can't read it. I want to update my firmware 1.0.4., but in order to do that I have to have my 30D serial number?????
    Brigadier General:
  • 11,967 Answers
Did you register your camera with Canon when you got it? If so, they have your number on file.
Posted on Mar 20, 2011
Kodak EasyShare Z1012 IS Digital Camera firmware update
If there is an update available, it must be on this site. But DON'T try to update a camera that is not 100% functional. You would end up with a camera that never can be used. read the update actions very careful. I can't get the firmware, because they ask what device I own. (serial number and so on)
KODAK Support
Jan 12, 2015 | Kodak Cameras
How do i update my gps
A GPS will help find the shortest and fastest routes to a particular destination. When the maps are out of date, the GPS may not be able to find the best route. A GPS should be updated at least once per year. Some GPS manufacturers will allow the user to download free updated maps; however, many manufacturers require the user to purchase updated maps. Updating a GPS map isn't complicated, and will take about 2 hours to install.
1.Turn on the GPS and plug the USB cable into the USB slot located on the GPS.
2.Plug the other end of the USB cable into the USB slot on the computer.
3.Insert the map update DVD into the computer. If you have a map download, locate and open the file on the computer.
4.Click on Update Firmware located on the main menu. Click "OK" when the firmware is finished updating.
5.Unplug the USB from the computer and turn off the GPS. This will allow the firmware to reset on the GPS. Turn the GPS back on and select the language and time.
6.Reconnect the USB to the computer and click on "Update Map," then click on "Load Maps."
7.Connect to the Internet by clicking on the activation link. This will display the activation number. Find the serial number located on the back of the DVD. If you downloaded the update, a serial number was provided. Enter the serial number and activation code into the update program to continue updating.
8.Close the program after it has completed the update, and unplug the USB from the computer and the GPS. Turn off the GPS to finish the update.
I hope you find it very helpful. Thank you for using fixya.
Aug 20, 2011 | GPS
I have error code #99 on a canon eos 30d
Error 99 is Canon's default for several "connection" problems most common are dirty contacts between the lens and camera body. Another is the contacts in the battery compartment both the camera and the battery contacts should be cleaned.
The camera might not be able to read the memory card, download the pictures to your computer and format the memory card don't delete them format the card this function is found in the set up menu.
Formatting is one of the most important functions to keep the camera and memory card communicating AND is the most neglected function. Always format a new memory card and always format a memory card after downloading pictures to a computer. Format a memory card if it's been in another camera.
Cleaning the lens and body contacts can be done fairly easily with a clean pencil eraser, don't use a puffer on the body as you will blow dirt into the camera. With the lens removed hold the camera as much as possible with the lens opening pointed down and gently polish the gold contacts. Do the same with the lens contacts make sure both areas are clean and re install the lens to the body.
Possibly the most important "fix" is to update your camera's firmware. Go to Canon's web site (it can be a bit intimidating at first) and search through until you find the firmware updates for your camera. Download this generally they want you to download to a memory card then place the card into the camera and upload the new firmware updates.
The Canon 30D (in my opinion) is one of the best no frills, greatest working DSLR cameras Canon produced. Not saying the model's beyond are not it's just the 30D isn't loaded down with video functions. Great all around working camera, sorry my rant for the day.
Cheers have fun with your Canon 30D
Apr 09, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
I have my Canon 30D set to manual but cannot change the f stop to anything below f/4.0. This lens should go to f/2.8.
Your camera body probably needs a firmware update to enable it to recognise the lens properly. The latest 1.0.6 firmware adds EXIF data for a number of lenses including yours to the camera. At the very least, you'll need to ensure that you have the latest firmware in order to eliminate it as a potential cause of your fault.
Sep 09, 2010 | Canon EF-S 17-55 f/2.8 IS USM Lens
Good day! Prompt please camera digital camera finepix a120 supports the memory card 1 gb and higher?
If your camera has a serial number starting with 4Bxx og 4Cxx, you may need to update the firmware.
Firmware is available her: http://www.fujifilm.com/support/digital_cameras/software/#firmware
Aug 06, 2010 | Fuji FinePix A120 Digital Camera
Need the serial no for my panasonic HDC-SD1 camcorder
Do a model number search instead of serial no. The manufactor's website usually go by model instead of serial number, for that purposes.
Dec 06, 2009 | Panasonic HDC-SD1 Camcorder
Sansa does not read the chapters in order, just 1-10, 20, 30 aso
You play audible books, right? What is your firmware? Some old firmware have that bug. You should update the new firmware. Go to the web sandisk forum to get your update.
http://forums.sandisk.com/sansa/
Good luck
Nov 02, 2009 | SanDisk Sansa Clip MP3 Player
Canon eos 30D digital Camera. I
I FOUND A COUPLE OF SITES TO TRY FOR THE SOFTWARE. I DO NOT ENDORSE EITHER SITE, JUST REFER FOR YOUR USE. HOPE THIS HELPS YOU!
www.usa.canon.com/consumer/controller
PCDriversUpdates.com
arclight1217
Nov 04, 2008 | Cameras
Cameras Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
