LE error code on front loader washer maytag neptune
    Brigadier General:
  • 6,277 Answers
Although I don't have LE on the list of error codes I suspect it may refer to Load Error, meaning actually that the machine itself is not balanced. Try these!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 20, 2011
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
My Maytag front loader washer gives an F H reading. Purchased in 2009, cannot locate owner's manual.
In the rear of the console inside is the diagnostic test sheets. They should tell you what error code means.
Jan 20, 2013 | Maytag Neptune MAH7500WH Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Our maytag neptune frontloader won't start
CHECK PLUG FUSE IF OK CHECK WIRE FOR ANY BREAKS IF NONE THEN IT MAY BE THE ON /OF SWITCH IS FAULTY.
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
