Question about Refrigerators
GE Profile PSW23PSTA Refrigerator - The installed ice maker has icicles dripping down the back of the ice storage tray, and ice forming underneath the the storage tray in the mounting tray. I submitted to FixYa for this problem a couple of months ago, and thought that the problem was fixed. However, it was not. My icicle problem had returned. I ended up replacing the ice maker a month or so ago, and things looked OK for a few weeks, but the icicle problem is back again since a couple of days ago. I think something is melting the ice cubes in the tray, or unfrozen water is going into the tray when the refrigerator thinks that the ice cubes are ready (but, they aren't). The ice in the storage tray is usually melted on the left side, forming a solid block, while the right side of the storage tray has regular cubes.Since two ice makers shown this problem, I don't think it is just the ice maker anymore.
  • 5 more comments
  • Alan Diamant Mar 21, 2011
    Hi, Macmarkus!
    The unit is about 3 years old.
    You raised an interesting point about pets: We do have a couple of animals that shed, and the refrigerator is in a confined area (behind a custom-cut cabinet space). Where is the condenser located at? I think it would be a good idea to try cleaning it as the next step.
  • Alan Diamant Mar 22, 2011
    Thanks, Macmarkus! I will be trying this later today. Note that it may be a week or so before you hear back from me on this again, since it takes about a week before the problem comes back and repeats. It's a bit frustrating that it has such a long cycle time before repeating. I will let you know how it goes either way! Cheers!
  • Alan Diamant Apr 02, 2011
    Hi, Macmarcus!
    Sorry it took so long to get back to you, but I needed to be sure that blowing out the condenser did the trick. It looked promising. The ice seemed to be fine again for a little over a week, but today the same problem came back - We see that water is in the ice tray again. The temperature reading for the freezer section says 3 deg F, but I'm guessing it's actually higher than that. There is some raspberry puree stored just below the ice tray that is normally frozen solid, but is slightly liquid now. Using an IR thermometer, most of the food is reading around 22 deg F to 37 deg F in temperature. So, it is probably more than just the ice maker with the problem - the whole freezer section may have issues. Let me know what you think!
    Thanks,
    AzJazz
  • Alan Diamant Apr 04, 2011
    Hi, Macmarkus - I have ordered the control board. Hopefully, it isn't too painful to replace. If you can send me some instructions (or, the service manual), I'll be ready to install it when the board arrives. Thanks again!
    AzJaz
  • Alan Diamant Apr 07, 2011
    Hi, Macmarkus - I received the replacement control board today. It didn't come with much information on how to replace the board. Can you please provide some guidance?
    Thanks,
    AzJazz
  • Alan Diamant Apr 08, 2011
    Hi, Macmarkus - I replaced the board tonight. It may take a week or more to see if everything is OK. I'll be sure to let you know either way, of course! Thanks again for all your help! - AzJazz
  • Alan Diamant Apr 13, 2011
    Hi, Macmarkus!
    I think the controller board replacement did the trick! The ice has been solid, and freezer section is actually reading around 0 degrees on most food items in the freezer (food was reading in the 20's to 30's before). Two things: How do I rate your service? (Which has been fantastic!) When I closed Fixya items in the past, I don't remember actually rating anything. Also, I'd like to send you future business from my friends - Is this possible with the Fixya system? Thanks again for everything! - AzJazz
  • Refrigerators Master
  • 2,605 Answers
Welcome to FixYa.
I'm not sure if you've noticed any other oddities with your fridge, but I've experienced this issue several times and every time it has been the main control at the back.
i.e. similar to this ( yours should actusally be WR49X10152 based on the model number provided )
The reason ? With electronics this can be very difficult to trace, it usually begins with a hunch based on my experience...as well as info gathered through communicating in detail (sometimes to a point they look at me funny, but that's OK) with my customers.
What happens with a faulty control is this, the entire unit system shuts off ( except the icemaker, water, lights and display ) for an extended period of time (normally it's 20-30minutes for defrost) but stays off too long thus melting the cubes in the mold and then the harvest cannot be "dumped" hence the ice-maker overfills the next time calling for water to make the next harvest.
This may occur several times a day or once a week, with an electronic control it can be very intermittent.
**The other possibility is the unit is actually cycling "off" via the overload on the compressor. This can be typical of a fridge which has an excessively dirty/blocked condenser ( if one has pets it should be cleaned/vacuumed every 3-6 months ) or extremely hi ambient temperatures, built into a cabinet with little or no air flow around the cabinet etc.**
I however do not think it has anything to do with the ice maker itself, as you alluded to.
How old is this unit ? Do you still have the owners manual ? If so look up the warranty coverage, the solid state components (electronics) are sometimes covered for 2 to 5 years, parts only but....worth looking into.
Let me know what you find or If I can assist you further. Good luck.
Regards,
Macmarkus :)
Posted on Mar 20, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Mar 21, 2011
    Hi, thanks for the reply.
    I agree cleaning the condenser is a good next step. If you pull the fridge out from the cabinet, the condenser will be located at the bottom in the back on the right when facing the back.
    You will need to remove the metal panel at the lower part of the rear cabinet and the condenser will be a canister shaped set of coils with fins. Think of it as a squirrel cage shaped radiator for a car.
    It should help you to have this blow-up illustration, and picture...hopefully. It may be difficult to clean and unfortunately somewhat messy as the best method is blowing it out with compressed air, or alternatively a vacuum. The vacuum doesn't do nearly as good a job however.
    **please unplug the unit from the wall before servicing...safety first** ...Careful not to knock any wires loose as well**
    CONDENSER ASSY.
    PART ILLUSTRATION
    Let me know how you make out. I'll watch for your reply. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 22, 2011
    That sounds good, I'll be around and watch for your post. With a little luck after cleaning the condenser it may work fine...time will tell though.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 03, 2011
    Hello again AzJazz,
    Sorry to hear the problem has returned/persisted. Based on what we've discussed to this point it all points to the control unfortunately...yours should actually be WR49X10152 based on the model number.
    The reason the temp is rising is the unit is not coming out of defrost soon enough after it's normal cycle...that is dictated via the control at the back as well as the defrost thermostat in the freezer as I alluded to in my previous post.
    It's a bit ironic actually, I just had the exact unit last week in the place I do service...that's about 4-5 in the past year. I used to think it was possibly a defrost thermistat/bi-metal until attempting that a couple of times.
    What happens is the defrost thermostat closes after the defrost (as it should) but the compressor relay doesn't close on the control board, thus it doesn't come on when it should...faulty board.
    Finally changing out the control each time resolved the issue. Let me know how you make out or if you aren't clear on how to change out the board. I'll assist you in any way I can going forward of course.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 07, 2011
    Hello again,
    I'm surprised by that. The place I purchase those controls is at "searspartsdirect.com" and it usually has instructions enclosed.
    Anyway,
    If you slide the fridge out from your enclosure/cabinet and observe to the lower right (from facing back) you'll see the small metal panel as shown in this illustration...
    **Unplug the unit from the wall of course...safety first**
    Once you remove the screws holding the control in place you'll see the control which is only held fast via plastic tabs. Take a photo of the wire connections and swap them from the old control to the new and you should be fine.
    Let me know how you make out of course and if I can assist you further I'll be around. Good luck again.
    Regards,
    Macmarkus :)
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
My GE Arcitia refrigerator ice maker makes ice but sometimes the ice in the bin starts to melt and drips down inside the freezer and makes big icicles.
You have a leaking valve allowing to much water into into the tray. Its fairly easy to change out. It could also be the defrost terminator is allowing it to stay in defrost too long. If it is only the water, yet ice cream stays hard, it is for sure the valve which is about $30.00. It is located in the back down at right corner. just pull off plugs and replace with new one.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Oct 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
May 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
Refrigerators Logo
416 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
