Question about Exercise & Fitness
I need a manual for the powerjog j series....i need to access the secret buttons to self diagnose the running machine diagnostics....if it helps there is a chassis number je061 many thanks in advance deano]
premtech
  • 934 Answers
SOURCE: Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Bill
Posted on Sep 27, 2008
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
  • 401 Answers
SOURCE: trying to have machine do a diagnostic on it's self for help
THE TECH SHEET SHOULD BE ON THE MACHINE.EITHER BEHIND TO TOE PANNEL OR THE DOOR PANEL.MAKE SURE IT GOES BACK THERE WHEN YOUR DONE.!
Posted on Jan 16, 2010
SOURCE: Can't access secret menu on digivox xl
Go to main menu. Select system information. Then type in 1004.
Posted on Feb 26, 2010
alicantecoli
  • 22326 Answers
SOURCE: Hi , would you send
its difficult to get pdf car manuals and even more difficult to get them to load on this answer ,try looking on this site as some manuals do exist though and their free .try a motor factor for a haynes manual but be warned these are not normally very good ,found my PDF manuals but nothing this new iam afraid but i will try the V6 engined sonata as it may be of some use for the engine timing marks .No sorry it will not allow me to upload a pdf document
Posted on Dec 21, 2010
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
Tip
Self Diagnostic test
Having troubles with your Axim x51V?
You can allow the device to perform a self diagnostic test that will make it run a series of tests (CPU test, LCD test, RAM test, Interactive Button test, Sound and Recording test, Touch Panel test)
To enter the diagnostic area, Press and hold POWER and RECORD while pressing the reset button on the back. Continue to hold the POWER and RECORD buttons while releasing the reset button and wait for the screen to show the diagnostic window. Select the envelope icon button to begin the test or press calendar icon to exit and reboot without testing.
on Mar 14, 2008 | Dell Axim X51v Pocket PC
Self diagnostics for a PSDS5YGXBFSS
There is but is is a series of tests usually started by pressing both the freezer and refrigerator buttons at the same time. It is a complicated series of tests and would be difficult to explain here.
Apr 02, 2014 | GE Refrigerators
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
My cruise control does not work on my 2003 Ford Focus
Hi Fred,
There are several things that can cause your cruise control to not function. Anything from a bad speed sensor to a faulty speed control servo. It is impossible to tell you what is wrong without diagnosing your speed control system. Here is a quote from the vehicle manufacturer regarding this issue:
"Start by running speed control servo integrated self test diagnostics. The servo has integrated self test diagnostics which is a key tool in quickly and accurately diagnosing speed control system faults. Self test diagnostics are also the basis for starting speed control trouble shooting."
Please note that a diagnostic scan tool capable of accessing the speed control data is required for performing this task.
Oct 15, 2011 | 2003 Ford Focus
I have an error message on my powerjog treadmill
jx 100 powerjog displaying self diagnostic error-how do you find what the error is
Mar 22, 2010 | Exercise & Fitness
Trying to have machine do a diagnostic on it's self for help
Jan 16, 2010 | Dishwashers
How do you fix the "service suspension" on a 2007 Yukon. 2WD
You will need access to a data and code reading scan tool. then the diagnostic test equipment required to run the required tests. It can be a verry expensive venture if your going to do it your self. The other option is to bring it to a reputable shop who has already bought the equipment and alow them to diagnose it for a sugnificantly smaller fee.
I hope I could help.
Roy
Nov 15, 2009 | GMC Yukon Cars & Trucks
Exercise & Fitness Logo
238 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
