Question about Bugaboo Baby Gear
Good day. I have a bugaboo Frog. I need to remove the two large outside chrome caps that seem to conceal the main joint mechaisms. Can you please assist?
  • daw1775 Mar 20, 2011
    Thank you, but I have this manual, and it does not solve my problem. I need to remove the starlock on both sides of the bugaboo frogs center axis.
    I need to remove the starlock from both sides of my Bugaboo Frog's center axis. Can someone please help?
  • 2,418 Answers
These types of caps have serrated fingers that grip the main rod and say in place. Not always but, sometimes removing them will damage them where they can not be reused, so be prepared to replace them or find another way to secure the ends. The way to remove them is with a large screw driver or a claw hammer and pry them off. With some, the chrome caps will have to come off, then the finger grip portion will come off, but it will still need to be pried off. Hope this Fixya up.
Posted on Mar 20, 2011
  • 345 Answers
Here is a manual for Bugaboo Frog stroller that explains on how to use it. IT also shows other versions of Bugaboo's.
http://www.bugaboostrollers.com/assets/product_files/instructions/Bugaboo/Bugaboo_Frog_manual.pdf
Hope this helps.
  • Mihajlo Jerkovic Mar 20, 2011
    On this link there is option for live chat or email to support. Live chat is closed but should be open tomorrow. Sorry i did not give you any more info. Good luck.
    http://www.bugaboostrollers.com/custserv...
I can't open/close my bugaboo frog smoothly. In the demo, you're supposed to push the middle bar while holding on to the handles and the swivel wheels will just pop open. I had to use my other hand...
Silicon Spray is the best lubricant for strollers. Avoid oil based lubricants like WD40. Main reason is they stain fabrics second reason they stay wet and attract dust and dirt, Click here for a more important place to use Silicon spray.www.fixya.com/support/r6671290-bugaboo_handle_lock
Jul 18, 2011 | Bugaboo Frog - Aubergine Stroller
Where can I get a tube for my bugaboo frog? You can not order from the bugaboo site.
For genuine parts try here www.babycare.nl/spare-parts-bugaboo-frog-c-34_124_174.html But your local bike shop will have a inner tube as lot's of Kiddy bikes have the same size.
Jun 20, 2011 | Bugaboo Frog Stroller
I need to remove the two outer round chrome pieces that conceal the main joint mechanism of the stroller. How might I accomplish this?
Click on my name and check out my tip section. The full how to with photos is there. I also sell replacement parts and will deduct the $5 off the parts if you have to pay it.
Mar 20, 2011 | Bugaboo Frog - Black Stroller
When I open the frame of the bugaboo, I push the knobs towards me and I successfully lift the handlebar up. When I try and lift the handlebar up to kick the wheels out, I can sometimes do it but at other...
There a three parts / assemblies to a Bugaboo Chassis that all pivot around the central hub (the thing with the large chrome domes). The white release buttons only control the handle locks in the outer set of hubs. The two wheel assembles are locked by the seat / bassinet clipping on to the frame and locking the inner hub. This hub is the heart of your Bugaboo and there is a reason Bugaboo put a can of silicon spray in the maintenance kit. Keep those hubs and the brake lever well lubricated and you'll get good service from your Bugaboo. Check out my Tips section for more info.
Jan 14, 2011 | Bugaboo Frog - Black Stroller
My bugaboo frog is stuck in the open position. something is wrong with the mechanism on the chassis that collapses and opens it.
You have two options if your Frog is out of warranty. Buy a new frame, this is around a third of the cost of a new Bugaboo but will add value to your resale price or repair it. Here's my How to fix a Bugaboo Handle instructions Cost varies depending on what parts you need to repair or replace.
If you are not a handy person type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods or a broken locking rod.Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me! They are critical components with a history of failing!
1/.Remove the capped star lock washer.This is the hardest part of the job.Most people try to leaver this off in the hope of re using.First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement.A hardware store should be able to source some for you.Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver.Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel.Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side.The hub and disks are mirrors of each other and not interchangeable.The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/.The lock mechanism is very simple; a wire rod rotates a plastic disk.Check the hubs for ware.If too badly worn or damaged you will have too much movement in the locked position.The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from.They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub.You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in.Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/.Reassemble handle locking hub and check operation.If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action)If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.Repeat operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacement locking rods in stainless steel and capped star lock washers you can contact me at macnutz@xnet.co.nz
Dec 11, 2010 | Bugaboo Frog Stroller
Hi, the main hinge (side silver hinge) on my bugaboo frog has somehow broken internally, now the whole pram does not stay rigid or locked. How can i get this fixed?
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me! Or a broken locking rod
1/. Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel. Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacenment locking rods in stainless steel and capped star lock washers you can contact me at macnutz@xnet.co.nz
Regards
Nov 11, 2010 | Bugaboo Frog - Blue Stroller
Bugaboo Frog Handle Won't Lock in Place
Hi
Visit www.buggypitstop.co.uk/ they can help
thanks
May 05, 2010 | Bugaboo Cameleon Jogger
Baby Gear Logo
35 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
