Question about Minolta Office Equipment & Supplies
My Minolta CF 1501 color copier shut down with a malfunction code C0060, I cleared the paper pileup and need to know how to clear code.
    Sniper:
  • 57 Answers
It is a fuser motor error. Check that. If there is a problem with that motor, unless you clear the actual problem the error will not go away.
Posted on Aug 03, 2008
Cob08 error
If your copier is Dialta 250 reset the malfunction code.
Push the warm restart switch located on the right side to control panel in area of display contrast knob(hole) and enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screenis being displayed.Select the trouble reset and touch exit.
Feb 11, 2013 | Minolta DiALTA Di250 All-In-One Laser...
Please describe your MALFUNCTIONING CODE C 1200 OF bizhub 8031 copier problem:
Clear the trouble code with the following procedure:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch.
3. The code should clear and a message to close the front door should appear
Mar 13, 2011 | Minolta BIZHUBC351 Color Copier
Minolta CF2001 has error coode C0060 after clearing a paper jam in the fuser unit.
well the fuser motor is jammed. remove the fuser and replace it. hopefully the motor is not burned out, and or worse the motor took the control board also
Nov 11, 2009 | Minolta CF2001 Copier
Printer was working fine then the error light started to slowly blink. Checked for paper jam and found nothing. Cleared out dust with canned air, still error, shut off then unplugged from usb port and from...
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Jul 29, 2009 | Konica Minolta PagePro 1350W Laser Printer
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
Minolta Dialta Copier
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!
May 10, 2007 | Konica Minolta DiALTA Di200 Copier
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
