Question about Bugaboo Frog - Black Stroller
I need to remove the two outer round chrome pieces that conceal the main joint mechanism of the stroller. How might I accomplish this?
    Guru:
  • 541 Answers
Click on my name and check out my tip section. The full how to with photos is there. I also sell replacement parts and will deduct the $5 off the parts if you have to pay it.
Posted on Mar 21, 2011
Hey all! Does anyone know how to remove the wheels on a Pliko Matic. Its a older stroller. I cant figure out for the life of me how to remove the wheels and my Google searches are failing me. Thanks!
Lots of such wheels are held on by little hub caps.
The axle is generally a plain-ended round bar or pin onto which the wheel is placed followed by a single-use spring steel star grip cleverly disguised with an integrated chrome or plastic cover.
Careful prising with a screwdriver working around it can sometimes remove the clip fit for reuse - but not often.
They are a common retainer and repairers mostly keep a stock.
May 12, 2016 | Peg Perego Pliko Matic Umbrella Stroller
A chrome piece (1 of 4) on the front grille broke off on my 2005 Kia Sportage. I need to remove the grille to get access to the screws that attach the chrome piece.
Hi there my name is Brandon I am a mechanical n electronic engineering technician I am the man reg mechanics call when they cant fix something it may have a spring you may have to push both side in to get it out some are a pain
Feb 02, 2016 | 2005 Kia Sportage 2.0
Need info for outer door handle R & R 2011 vw Tiguan.
1. Open the door.
2. on the door appature above the lock mechanism toward the outer skin of the door you should see two holes one ovalish shaped and one round shaped.
3. pry covers off circular hole (inner).
4. insert hook type tool (if you dont have one make one by putting a cheap small flathead scredriver in the vice and bending it into a small L shape at the end about 5mm.
5. pull latch mechanism loose (you will have to look for the latch with a small light or feel around for it.
6. put outer door handle capping (the stubby part) out by prying off gently and then wiggling.
7. slide main part of door handle toward newly exposed hole created by removing capping and then remove.
8. thank me for saving you from tearing your hair out. If we all bought Japanese we wouldent have these ****** problems.
Sep 20, 2011 | 2009 Volkswagen Tiguan
The springs appper to be broken. I can no longer
Inside the right-hand hub there are three components, two metal pieces approximately the shape of a rounded J and an concentric cam (looks like an oversized washer about 5mm thick with notches taken out to allow it to turn when pulled which is turned by the button/slider on the handlebar.
The 'j shaped' pieces are held in place by spigots have probably have sheered off leaving the mechanism locked in place.
The Bugagboo final assembly process forces a chrome cap on to the end of the handlebar & legs axle - sadly this requires specialist tools to saflely reinstate so they insist on return and replace and will only do that if you're under warranty.
I'm looking at a work around involving
Putting in two brass spigots and replacing the locking cap with either an over-sized circlip or a split pin and washers.
Sorry it isn't better news
Feb 20, 2010 | Bugaboo Cameleon Jogger
Bugaboo Cameleon
There a company based in London www.buggypitstop.co.uk and they do repairs to bugaboo's
Oct 03, 2009 | Bugaboo Cameleon Stroller
Change the front wheel bearings on a 2005 taurus
Remove wheel
Remove axle nut
Remove outer tie rod nut
Leave outer tie rod nut on 3-4 threads
Hit spindle area where tie rod is mounted very hard with a large hammer (wear Saftey glasses)
The tie rod should loosen up and you remove it off spindle.
Remove lower ball joint nut
Leave nut on 3-4 threads
Hit spindle area where ball joint mounts (wear saftey glasses)
Carfully pry down the lower control arm too remove ball joint from arm.
Press in the axle towards the trans. out of the wheel bearing.
Place a piece of wood between the shock and inner fender to give yourself room to work.
Remove the three 15mm bolts that hold the wheel bearing on.
Hit wheel bearing out with hammer (wearing saftey glasses)
You may need to break a sweat on this part. Somtimes they are rusted in.
Be carfull not to damage the ABS sensor.
Reverse procedures to install
Sep 08, 2009 | 2005 Ford Taurus
Gas-spring mechanism has stopped working on my 2006 quinny buzz :(
I sent my frame to dorel and they fixed the same problem quite cheap to do if you remove the wheels etc they were quick to send back too phone them on 01842763281
Sep 12, 2008 | Quinny Buzz Jogger
Zooper Zydeco
Our stroller had a similar break, just below the 'pivot point'. I have been in touch with Zooper directly (Dan Slaughter - dans@zooper.com) and had a new piece shipped to us in Toronto for about $20 American. Removing the old piece wasn't too bad, but I did have to drill out the old rivots. I am however having problems reinstalling the new piece, because of the wires contained within the steel frame (which allow the folding function). If you can do without the folding function, you're laughing. That's what I'm considering doing. Hope this helps. Jason.
Jan 31, 2007 | Zooper Zydeco Z344 Jogger
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Bugaboo Frog - Black Stroller Logo
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
