Question about Vacuums
How do you programme 13A remote control for W.H.Mandolyn int'l Ltd model no.TR-502MSV
Filled with water, pressed both buttons and nothing happening ??
Are you sure it's plugged in and if so, is it plugged into a live socket?
Nov 02, 2013 | Polti 3000 Vaporetto Eco Pro Steam Vapor...
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
I need to take apart my Kenmore Progressive Bagless Upright with Inteli-Clean System
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Jul 29, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
No power
This is a dead motor. the electrical motor is experiencing windings failure and will have to be replaced or rebuilt. Just to be safe, remove the switch and test with voltage needle to see if the problems here. i suspect total motor failure.
Mar 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Power Switch for Fantom Lightning
I think that the marking is 5E4, not SE4
Nov 18, 2007 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
571 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
