Question about Apple iPhone 3G Black Smartphone
My iphone 3G will not turn back on... it shows the apple symbol and then goes back off then it shows up again and again.. what should i do?
  • 19 Answers
You need to hold bouth keys power and home untill the iphone is not switched off,and than switch it on again,untill the apple is on the screen..
Posted on Mar 20, 2011
My G3 phone is flashing the apple symbol while powering up but isn't powering up.
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPhone 3G.
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
• This hard reset process should help bring your iPhone 3G back to normal functionality.
It would also be advisable to connect your iPhone 3G via its docking cable and provided wall socket adapter into a working wall socket in order to try and charge it.
If your iPhone 3G still does not charge, try connecting it with the docking cable to your computer or laptop to observe if it will take a charge then.
Should this process also not affect the way the iPhone charges, then you should look into using or purchasing another iPhone docking cable, as the cable itself may not be functional and needs to be replaced.
Docking cables for iPhones are fairly inexpensive (Under $20) and can be found in most electronics/computer stores that carry Apple products and accessories.
(Link: Apple Dock Connector)
Finally, if a replacement docking cable does not help the iPhone 3G charge, this may be a hardware issue and you would be advised to take the iPhone 3G in to your local Apple retail store or Apple Authorized Service Provider in your area.
Regards,
-The MacTechTrainer
Aug 07, 2012 | Apple iBook G3 Mac Notebook
Iphone 3g stuck on apple logo after jailbreak
hy,??,????????iphone?????,????????????,???????(vipprogrammer.com)????DIY????,?????????,
May 21, 2017 | Apple iPhone 3G
My iphone 3g is jailbroken 3.1.3,was working fine then one day after a text from a person it just suddenly shut off? thinking it was dead battery, i plugged it in, apple symbol came up and i left it to...
Unfortunately there is not a lot of support from Apple or the jailbreak community for iphone 3g, so there isn't really anything you can do to make it operational again.
Mar 01, 2011 | Apple iPhone 3G
Iphone 3gs shutdown and won't turn on
hold your home and sleep button until you get an Apple Symbol then it will load again
Dec 12, 2010 | Apple iPhone 3G
Apple iphone 3g 4.1version after unlocking one dya is worked properly then showing no service
Turn off you phone and then turn it back on again. If you leave your phone on for extended periods of time the phone for some odd reason decides to lose cell service.
Simply restart your phone and all will be well.
If this does not fix your problem, you will need to take it into the Apple Genius Bar as the logic board may be malfunctioning.
Dec 10, 2010 | Apple iPhone 3G
I have a jailbriken iphone 3gs and i cleared the phone of all saved data aka contacts etc. and pulled the sim now its frozen on the aplle symbol and a frozen infinte swirl of death
Try reinserting the sim and resetting the phone.
You can do this by holding the power button and the home button at the same time until the phone flashes and powers off.
Then power on again. The Apple splash screen should show for awhile but eventually turn back on.
Sep 16, 2010 | Apple iPhone 3G
Phone indicates connection, but won't make or receive calI.
My phone does this as well. Just because it shows service doesnt mean it has service. If you are in an area that has spotty service trying going to a place you know to have perfect service and try again. If the problem persists call ATT and they should help you through the problem.
Apr 15, 2010 | Apple iPhone 3G
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2009 | Apple iPhone 3G
My iphone 3G is not starting. It only shows apple logo for few seconds & then goes off again. Pkease Help
Hello, it sounds like your iPhone either needs a new battery or has been water damaged which has damaged the phones power managment.
Book an appointment with an apple genius, they should be able to help you.
Nov 01, 2009 | Apple iPhone 3G
Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Jun 01, 2009 | Apple iPhone 3G
Apple iPhone 3G Black  Smartphone Logo
107 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
