Question about Oreck XL Professional Air Purifier
Has not made the zapping noise in a long time...I know my house is dusty :)...used to make the noise before...is the cell worn out or broken
    Brigadier General:
  • 4,736 Answers
The air intake filter probably needs cleaning or replacing. If it needs replacing, you will have to buy that from your local Oreck dealer.
Posted on Mar 20, 2011
  • Kellie Mar 22, 2011
    Sorry it took me so long to get back to you...Thank you very much for your quick response...I'll check on the filter and let you know if that was the problem:)
  • Rich Landrum Mar 22, 2011
    Not a problem. I hope it helps clear up the problem for you. Have a good evening.
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
Aug 20, 2017 | Air Purifiers
Carrier Infinity air purifier makes constant zapping sound when operating with door in place.
It sounds like static electricity being generated through the filters. I suggest you change the filters and see what happens!
Jan 10, 2013 | Air Purifiers
There is a blue spark and bug zapping sound-looks like its sparking on the ceramic ozone plate. The place looks fine-no cracks.
It's doing exactly what it's supposed to do. The bug zapping sound is from dust particles in the air, that's being pulled thru the unit. However, it should not being doing in continuously (unless your home is really dusty), it may simply need cleaning. Cleaning the unit, about once a month is recommended.
Hope this helped you.
Jun 16, 2011 | Ecoquest Flair Air Purifier
Makes a zapping noise when you turn on the electronic air cleaner
If the the "zapping" noise you hear is intermitant (like a Bug Zapper) it's probably dust that the air cleaner is picking up from the household air. .If that's the case, there's nothing to worry about, it's doing it's job.
If the "zapping" sound is continuous, then the unit may need cleaning, as it may be clogged with dust & lint.
Feb 08, 2011 | Air Purifiers
One of my Honeywell F50F cells (FC37A1130) arcs incessantly. Everything is clean, and I can't spot a broken wire, touching plates, or anything like that. The area of arcing is very definite (I looked...
I had a similar problem with mine. It looked to me like the vanes were fluttering and causing arcing. I found an old piece of comb and slid the tines between the vanes to stabilize them. You might have to try it several times to get the position just right. So far its worked for me.
Feb 22, 2010 | Honeywell Air Purifiers
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Environcare unit is not crackling.
Check the connections to the air cells (precipitators) and be sure you have a good connection - make sure none of the cell plates are touching each other
Mar 07, 2009 | Honeywell Air Purifiers
Thin wire broken in front
Describe this wire, is it a small silver shiny wire? It is most likely the ni-chrome wire or high tension wire that zaps the particles, I would think thay would have that part available have you called them?
wbwill@sbcglobal.net, if it is obsolete you can mail it to me and I will take a look
Nov 12, 2008 | Sharper Image Professional Plus Ionic...
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Oreck XL Professional Air Purifier Logo
414 people viewed this question
Top Oreck Air Purifiers Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
