Question about Pioneer PDP-4271HD 42 in. Plasma Television
My Pioneer 42" flat screen has lost color fidelity
5 Suggested Answers
  • 1694 Answers
SOURCE: Pioneer Pro-200 60" Rear Projection Color Adjustment
after market duplicate remotes are reasonably priced-search tv remotes on-line.
Posted on Sep 26, 2007
SOURCE: Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Posted on Nov 18, 2007
SOURCE: does pioneer model vsx 403 come with a remote control? If so how can you relace it?
I have the same unit. It does come with a remote. The original remote is pretty much impossible to find. But also there are some companies that sell remotes for it. Google Pioneer VSX403 remote replacement. I have yet to get a remote :D
Good Luck.
Posted on May 17, 2009
  • 19 Answers
SOURCE: Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Posted on Jun 12, 2011
The color contrast is off. The black color appears with a red tint, and the picture looks similar to a graphic comic. I have a Sanyo 32" flat screen.
The five times I ran into this problem on these model sets it was caused by bad main board three times and bad lcd display panel,(screen) one time, and bad solder connections at a connector on the main board the other time. You can try to search model number and board description for pricing. Chances are a repair shop will charge 100-400 u.s. dollars to fix this problem. Good luck with your new disposable flat screen.Russmann.
Jan 03, 2011 | Sanyo DP42849 42 in. HDTV
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
My 42" Samsung Flat screen
IS HE SCREEN TOTALLY RED !! if yes check power supply all voltages if normal replace x board
Apr 26, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
Apr 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
Aug 18, 2008 | Philips 42PF7421D 32 in. LCD HDTV
Pioneer PDP-4271HD 42 in. Plasma Television Logo
41 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
