Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Have a Maytag Model MDB4100AWB and the top wash arm needs cleaning but I'm not sure how to take the nut off without breaking it. What's the method of removing it? Thanks JB
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 14, 2011
Top water outlet doesn't spin
Not sure of the vintage of your Maytag dishwasher, but this may work for yours.
1. Remove the upper rack by releasing the stop clips on the ends of the rack rail; push the ends of the clips towards center of machine - this may require the help of a small screwdriver.
2. The upper spray arm assembly is mounted to the ceiling of the wash chamber by large (2" diameter) fluted nut that butts right against the ceiling sheet metal. Simply remove that nut by hand, and the whole assembly will come out.
3. Looking into the top of center feed hole, you'll see 4 plastic clip ends holding the 3 pieces together. Use a 1/4# socket or nutdriver to press all 4 clips inward until they come free.
4. The spray arm halves are welded together, so you'll have to clean out any clogs using a pointy tool and some water flushing.
5. Reassembly is the reverse order.
- Mike
Apr 17, 2014 | Maytag Dishwashers
Maytag washer top load ser# mvwx600xwo It's making
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWX600XW1/3048/0153200/W1104178/00004?blt=06&prst=&shdMod=
go here and look at parts,the nut number 14 in diagram comes loose and this causes noise from parts not lining up,this is an easy check,pull the washer forwards and then tilt it back against the wall, remove the bottom panel and then remove the shield part number 20 in diagram,check the nut and see if you can push the parts up that are above the nut,i've found this nut loose in a few machines,when you buy the new nut it has blue lock tight on the treads,if it is loose and you have some blue lock tight you can try adding some to the treads or buy a new nut if this is what you find,otherwise without being there i couldn't really help you out but check that nut first.
Apr 07, 2013 | Washing Machines
How to take off the top ball joint nut with an open end wrench without stripping the nut?
Usual method,Pull the cotter pin and use 2 open end wrenches,on top of each other to increase the contact area and pull slowly.The nut should come off.
2nd method,use a sharp air chisel and split the nut apart.
3rd method,shield the CV boot and heat the nut or cut it off flush with a torch.
4th method,freeze the nut with 134a and then remove it with the 2 wrenches.
5th method,Cut across it at an angle with an air cut off tool
down to the ball joint threads to release the nut pressure then remove it with one wrench.
Do you need more methods?
Apr 26, 2017 | 1996 Nissan Maxima
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
DOES NOT WASH CLEAN, EVEN WITH THE TOP SETTING. PARTICLES STICK TO INSIDE OF CUPS.
Make sure the filters and sumps down in the bottom of the tub are cleaned out, then check all the wash arms for any contamination, particles, junk anything that could restrict the flow of water through them, it sounds like the wash arms are not rotating because of no water flow. Good luck !
Nov 24, 2009 | Maytag Dishwashers
Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Feb 16, 2009 | Maytag 24 in. MDBH955AW Built-in...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Mar 12, 2008 | Maytag HAV2558 Top Load Washer
Maytag PAV2300
My opinion is no. You need those tools for reinstalling so you dont break the parts you are installing
Jan 05, 2008 | Maytag PAV2300 Top Load Washer
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
136 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
