Question about Sears Garden
I have a craftsman lawn tractor model 917.272670 17.5 hp that is stuck in gear and cannot get it in neutral or any other gear it has a six speed transaxle i noticed it was hard to get it in reverse when i was backing it out of the shed and got in forward and cannot move it at all i cleaned out all the grass clippings and cleaned all of the linkage too
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wont go into gear, stuck in neutral
Check and see if the belt to the rear end broke. Sometimes they will break and get wrapped around the pulley and will keep you from putting it in gear.
Apr 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower stuck in 3rd gear
you have a broken shifting fork in the transaxle, i know this, i just replaced one on a mower that was stuck in third gear...
Apr 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gear selector
SOUNDS LIKE THE BELT HAS CAME OFF OR THE PULLEY HAS BROKE
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Transmission reverse and 1 st gear, 20 hp
transmission and shifting problems are tricky. from the limited information given, i'll go on assumptions - if this is a hydrostatic transmission, your brake is stuck, it will need to be adjusted - if it is a six speed, several factors come into play. if it will shift okay with the engine OFF, but not with it running, you have a belt problem. has the belt been replaced recently? is it the correct belt? is the belt routed correctly? if none of the above, check the belt guides to make sure that a stick or something hasn't poked up there and bent them. their purpose is to make the belt "blossom" away from the engine pulley so there is no tension on the belt at the transmission. if it won't shift with engine off, the shift shaft in the trans is probably rusted and sticking.
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman model # 917.274031 garden tractor.
check the rear wheels,has you fixed a flat and not put a key back in or not fitted the wheel correctly.
Some hydro ?? cut out levers only have a spring to pull it back and get stuck.
Dec 08, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
186 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
