Trying to locate a Bussman Fuse-250 volt, 3 amp-one end is bigger than the other. It is for a vintage Zenith console stereo. Got it recently, it worked for about a week and blew the fuse and got a shock. Can't locate fuse to try to replace. The fuse also has a little lip on one end. Any suggestions on getting this running again. No power at all. A. Anderson
    President:
  • 2,992 Answers
Unless you are treating this as a collectible and want to keep everything as it was built, I'd suggest not worrying about finding the exact original fuse. Instead, find a convenient place to mount a chassis-type fuse holder that takes a standard 3AG cartridge fuse with the rating you need. Then clip the wires going to the existing fuse holder and solder them to the new one. (This is a common way around part availability problems when fixing old equipment. If you want to preserve the unit's original appearance, find a spot where the replacement part won't be easily seen. Leave the old part - disconnected, of course - in place, but the new one will take its place.)
The next step is to figure out what's gone wrong. With old electronic equipment, capacitors are a common problem. They break down with age, and can short. Also, rectifier diodes in the power supply can short out. It may also be a simple case of insulation on a wire that has become brittle and flaked away, allowing contact with the chassis. Unfortunately, this is also something that can happen in the unit's power transformer, which may be very difficult to find a replacement for.
What I do with old gear before ever plugging it in is to look it over. A visual inspection can reveal parts that are obviously bad or close to it (burned or discolored spots, worn insulation, swollen or burst capacitors, etc.). A few checks of common parts, like the capacitors and diodes I mentioned before, with an ohmmeter follow. If all looks good, I plug the unit into a device called a variac, which allows the line voltage to be controlled with the knob on top. Gradually raising the voltage avoids the sudden shock to parts that haven't been used in a while, which often causes them to fail.
In a case like yours, where something is already bad, it's just a matter of checking parts until the bad ones have been identified, then replacing them with something suitable. This is where experience helps. Having a schematic diagram of the device is good too, if one is available. There are many sites devoted to repairing electronic equipment, especially vintage or antique pieces, where you can find help. Search for the make and model of the stereo along with "repair and restoration" and you should be able to get started.
Good luck, and thanks for using Fixya!
Posted on Mar 20, 2011
I have RCA cables , How do I use my computer music ? What connections and settings?
Are you trying to play music off your computer through a stereo or receiver??? If so you will need a cord with red & white (rcas's) on one end & an 1/8" jack on the other...Run it out your headphone jack of the pc (usually color coded light green) and turn input of stereo to corresponding input you plug into..
May 23, 2016 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
I have a 250 volt 1500 watt Dough Machine. What size of wire I need and how much amperes of fuse I need?
Wire would be .75mm and fuse does not need to be bigger than 10 amps. Make sure your earth is correct, I do not expect it will be double insulated.
May 06, 2015 | Food Mixers
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
StaplesSPL-TXC22A fuse blown
The fuse is on the main circuit board when you take the top cover off (the brown board not the two skinny & long green boards). It's listed on the circuit board as a 10 amp 250 volt fuse. It's held into place by two "fuse holder end cap thingys" that are soldered on the baord. You could try to gently pry one side up until the old fuse came out but it would be better if you had a soldering iron and could de-solder one end cap and resolder it after installing new fuse. Btw: make sure the old fuse is bad before trying to get it out!
You will also need a very long philips screwdriver to get some of the cover screws out.
Dec 11, 2013 | Staples Office Equipment & Supplies
Vintage Audio Repair in the NYC/NJ area
The hum is a tube that has gone weak or a volume switch that may be going out! Try a TV repair shop in your area, and call first so they can tell you if they are familiar with the old equipment!
Oct 21, 2013 | Audio Players & Recorders
Meter fuse lamp 11/2 in 6.3 v 250 ma can not find one
http://www.ebay.com/itm/DYNACO-FISHER-MARANTZ-SANSUI-PIONEER-KENWOOD-JVC-OTHERS-HI-END-FUSE-LAMP-/370844118805?pt=US_Light_Bulbs&var=640100726899&hash=item5658082f15
Apr 18, 2013 | Harmon Kardon Vintage 70s Harman Kardon...
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
44 people viewed this question
 Grubhead
Grubhead
