I have the RCA P52960 52 in. Rear Projection Television and the picture just started bowing from the top and bottom in the form of a bowtie. I the post and was wondering if there was a way i could prepare it myself or should i call in a professional?
My name is steven. Its wierd that i have the exact same tv and it started the same problem on the same day. I can't tell you what is wrong with it unless it is just old like mine. Thanks for posting any solutions you find. I did take the back off it and check for loose parts. Everything is intact. I vacuumed the bulbs and the screen from the inside with a brush attachment and the picture is so much more bright and crisp but the bow is still there.?
Posted on Mar 20, 2011
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv picture has a top and bottem bow to it and picture seems to be too large as some stuff on the outside of the picture just gets cut off.
Replace your Regulator IC mounted on Board above bottom Bottom boards STK730-010 Call Mats for Part 1-800-628-1118
Sep 26, 2009 | RCA P52937 52" Rear Projection Television
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Bowed Picture
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Oct 06, 2008 | RCA P52960 52" Rear Projection Television
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
