My bang and olufsen avant 32" television, when I on it works for about 3 minutes and then it becomes green and white lines appear on the screen.The sound works perfectly.please let me know the cause of this problem and how much it would cost for the repairation? thank you, kind regards, Joseph.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Sep 10, 2017
  • 1153 Answers
SOURCE: Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Posted on Sep 14, 2007
Shuttle83
  • 1139 Answers
SOURCE: Green Screen
The lines are retrace lines and the green screen could be a problem with the picture tube or a problem with the video circuitry connected to the green gun of the picture tube. Troubleshooting must be done to determine the overall cause of this problem. Is it an easy fix. If I were in my shop and you bought this set in, it would be finished in a day. It being easy depends on the person, easy for me may not be easy for you, I have the equipment to fix this problem, and that is what it will take. let me explain: First I would use a schematic to show me the voltages that should be present on the picture tube socket board, for red green and blue. Then I would measure the high voltage on the anode and write it down (usually 20Kv to 30Kv) Then I would inject an known good signal into the TV (usually color bars) via the RF input on channel 3 From there I would make sure I write all of my measurements down and compare them to the schematic. At this point I would waant to make sure the picture tube could not be the culprit, I would power off the set unplug the set and then discharge the high voltage anode of the picture tube I have a tool that does this but it can be done with a big flathead screwdriver and a clip lead. Attach the cliplead to the screwdrive and then the other end of the screwdriver to ground. MAKE SURE THE SET IS POWERED OFF AND UNPLUGGED!! Manuver the flat blade of the screwdriver under the rubber cap of the anode connection on the top of the picture tube and make contact with the metallic clip (you may draw an arc so be prepared for an electrical discharge). Once you do that leave the screwdriver inplace as you remove the rubber cap and the metallic clip from the anode of the picture tube. Once this is done, remove the socket board from the back of the picture tube. At this point you will now use what is called a CRT Analyzer/Rejuvenator. Follow the setup and test instructions for the CRT Analyzer/Rejuvenator perform a tube check first and if the tube shows bad on any of the guns, perform a rejunvenation run on all threen guns, balance them and then test them again (repeat this about four times if needed), an more and you can count the picture tube as bad. If the tube is good or can be bought to a good state then reconnect the anode and socket board and reapply power. If the problem is gone then it was the tube, if not then it's the circuitry and then troubleshooting is needed, to find the problem in the video circuit. I hope this helps.
Posted on Sep 21, 2007
tvtechnician
  • 105 Answers
SOURCE: Vertical black line approx 3" in centre of screen with white line through centre.
you will need a new panel wich will cost you more than the tv itself.
Posted on Oct 14, 2007
SOURCE: Samsung WS32Z10R 32" with diagonal green lines across it at all times
it sounds like an ECU has gone due to a trip in the tube, that may meen the tube might be slowly on its way out, or just a slight glitch. mine had the same thing and it cost me £45 to fix. now its great. i hope that helped. Jay.
Posted on Dec 07, 2007
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
What's wrong with my TV
Open internal fuse or power supply failure
Jul 07, 2016 | Televison & Video
Bang & olufsen Beovision 7- Unable to turn television on When trying to turn the television on using the remote. WAIT appears on the top right side of television.
Nice TV set. Try first unplugging the tv for ten minutes, this quick hard reset will drain power from tv, and sometimes it solves the problem when TV is freezing on startup.
If this soes not work there must be a service reset procedure.
Aug 17, 2008 | Televison & Video
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
Screen goes green with white vertical lines
I think either your red and blue filaments are not fully intact causing the green to take over or you have other electronics like subwoofers too close to your tv.
Try degaussing your tv, it might have a degaus button at the back or check the menu.
If you've tried those things without luck, respond with more details.
Hope that helped.
Jan 01, 2008 | Zenith C32V37 32" TV
Bang olufsen mx7000
Check for any loose solder terminals at its video output card. This card can be located at the back of the CRT, will directly plugged on to it. Re-solder all the suspected solder terminals, by applying a little more solder. The fault can be categorized to 'sigle color predominant' screen.
Gopakumar Gopalan Google
Feb 12, 2014 | Televison & Video
The wire on my Bang and Olufsen has come off
this job can be done from the front but it is very fiddly so suggest youprevent hair loss by taking to b&o repairer.
Feb 06, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Bang & Olufsen Audio Tape Player Seized Up
probably needs belts but parts are discontinued.
Dec 27, 2008 | Bang and Olufsen Beosound 2000 Shelf...
MY beocenter 2 does not recognise any disk
I have blue lines across my Beovision 3 TV screen
Nov 04, 2006 | Bang and Olufsen Beosound 4000 Shelf...
Televison & Video Logo
Top Televison & Video Experts
