Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
No water entring machine when cycle pressed - Hotpoint 24 in. FDW60 Free-standing Dishwasher
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 20, 2011
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Dec 26, 2009 | Gaggia Titanium Espresso Machine
Message on my printer says (press entre to align
You need to blot the cartridges on a paper towel and make sure all the colors are showing, It won't complete the alignment until it can see all the colors on the alignment sheet. Sometimes you need to blot on a damp paper towel to get them flowing.
Oct 30, 2009 | HP PSC 950 All-In-One InkJet Printer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
53 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
