Question about Intel Easy PC Camera Webcam
I have have had ab Intel PC Camera for about 5 years and it has worked good up until I just purchased a PC with Widows 7. I tried to install an update program that I used for windows XP and the computer says it is not compatible with the new computer. Is there another update? My computer is a new HP Pavilion p6754y-Gray Edition. P6000 series. hrs25@msn.com Hal
  • 823 Answers
I can help you with this - but the oly way for you and I to have clear instructions is if we are using the same set up. To ensure this, let me have you temporarily change yours to match mine and when we are finished fixing this problem I will walk you through returning the settings to your default. Agreed? If so then continue:
go to your control panel (usually found by clicking the round ball at the bottom left side of the screen which we will call "start" from this point on for this repair) by clicking on start and then finding the words "control panel" to the right. click on it and look for "taskbar/start up menu" and click on it. There are two tab choices at the top. Click on start up menu and then click the bottom box for classical setup. Click on apply and then "ok" and close this area.
Now you are running classical start up the same as I and this will help me direct you to fix your camera issue. Here we go!
Click on start on the bottom left of your screen, then click on "devices and printers". If your camera is connected and turned on you will find it here. To turn it on or use it, right click with your mouse and use the drop down box options it provides.
If you want to use your camera automatically, you will need to go to the manufacturers website and find a driver disk that is compatible with Windows 7. Go to intels website (search and find it on the internet) and the find support or software/driver updates. Check to see if your camera is compatible with win 7, if so download the driver it needs to run the camera. Then make sure you have the same picture software installed on your Win 7 pc that you did on your Win Xp. There are many program available that will work with this camera such as "Ulead", "Arcsoft" and even "Paint" which is a default on post computers.
Open the software you want to use with the camera with it connected and turned on and your pc should automatically sense it and configure the software to work.
now go back and turn your taskbar setup menu backto your version if necessary by going to "start" control panel, taskbar/start up menu, click the "start up menu" tab at the top and choose the box for the set up above classical. then choose "apply" and "ok" and your done.
Posted on Mar 20, 2011
Unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Sep 21, 2012 | ASUS Computers & Internet
I lost my instalation cd of intel cs110. and now iam using the windows 7 os . plz tell me the solution to intaling the device
Dude ! this is the link for window xp for your camera . and try ot install it in window 7 if it works the good or not then i will search drivers for it . http://download.cnet.com/Intel-r-PC-Camera-CS110/3000-2110_4-104418.html
Sep 03, 2011 | Intel Easy PC Camera Webcam
I want the intel D865GSA motherboard's audio driver for using on windows 7.....Plz.....Send me that driver to my mail id....plz send me....
Firstly you should turn on automatic updates with windows 7 as this supplies the computers software with missing drivers. however if it does not i suggest you try the manufacturer of the board website, more often than not intel website will have audio drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
May 31, 2011 | Computers & Internet
I have the Intel Pro cmera it was working on Vista now I have WIndows 7 ultimate and it will not work. when I try to use it on yahoomessenger it say webcamnot found on system
Update drivers using windows update option or install the same drivers which been used for vista, the drivers will be work on windows 7 as well.
good luck
Mar 07, 2011 | Intel Pro PC Camera CS430 Webcam
I have a new Dell PC with Windows 7. I have the
Try going to your camera manufacturers web site. Follow the Support/Download pages to your specific camera to see if there's a new driver for Widows 7.
Mar 22, 2010 | Cameras
Purchased new computer with Windows 7. When I
Go out to the camera's manufacture web site and check to insure that the camera is compatible with Windows 7, if it is download the latest drivers from their site. A lot of older devices are not compatible with Windows 7 or you just might need newer drivers.
Jan 05, 2010 | Intel Easy PC Camera Webcam
Aser 5738 laptop bluetooth not working on widows 7
You will probably have to look on the net for a driver that is compatible with windows 7 for your bluetooth device. If you cant find one designed for windows 7 you could try a driver made for vista as many vista drivers work for windows 7 devices as well
Sep 21, 2009 | Acer Aspire 5720-6661 Notebook PC
When i use xp ,the install cd says"no compatible drivers"..
Go here to Intel support, download and install your audio drivers, there are 2 drivers so you may have to try them both >>>>>>>>>>>>>>>
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2613&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Good luck.
Jun 29, 2009 | Intel D945GCL Motherboard
Intel Easy PC Camera Webcam Logo
178 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
