Question about Envision Monitors L19W698 19 in. LCD TV
Envision L19W698. TV has worked fine for several years. Suddenly some of the colors seem to have gone. There are white patches all over the screen. It is the same on HDMI and s-video. The same if I try the set with another U-verse receiver. I also changed HDMI cables. It seems to be a TV problem. No changes have been made to the color settings. When the set switches on rather than the usual blue color screen it is now a pale green color.
  • 2 more comments
  • charlesbeech Mar 20, 2011
    3 years old maybe 4 at the most
    will do - how do I upload an image to fixya??
    sorry the file is larger than 150KB and there seems to be a problem with imagehosting.com give me a few minutes
    no luck with imagehosting - thx for the help anyway.
  • 4,889 Answers
This sounds like a problem with the LCD controller or the the LCD panel itself. How old is the set? That will give me and idea of whats the possibility of the panel going bad.
Posted on Mar 20, 2011
  • 2 more comments
  • eagle338
    eagle338 Mar 20, 2011
    Then its probably not the panel however I would like to be sure. Can you please upload an image on fixya or on some imagehosting site and get me the link to it?
  • eagle338
    Press the add comment button at the top right corner of the page. When the comment box opens click on pictures snd browse the picture. Remember that the image size must be less than 150KB. if its larger than that then please upload to an imgehosting website like
    http://www.imagehosting.com/
    And get me the link to the image.
    Sai.
  • eagle338
    Surething take your time
  • eagle338
    Yes I see the site is down, Try photobucket then
    http://photobucket.com/
Envision menu lock
Refer its user manual for details. Try this link to download the manual. Envision L19W698 LCD TV User Manual
Feb 03, 2014 | Envision Monitors L19W698 19 in. LCD TV
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
Incidentally, i am using the monitor as tv, not computer monitor--it is hooked to the satellite(Dish)--image is perfect, but no sound. The adjustment on the remote works, and I can see that it thinks it is...
Hi well i assume you are using the HDMI output? or maybe you are using the ordinary Video out? In any event what you may need to do is hook up also the Red & White Stereo Audio... on the TV to the Output of the PC's sound card. This will then give you sound.
Also when changing the sound NOW when using the two you must control the sound by first setting a volume on the TV with the Remote, and set a level, then ALSO you can adjust this as well with the remote or Volume control of the receiver, ie: The PC's volume,
Oct 10, 2011 | Envision Monitors L19W698 19 in. LCD TV
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
Envision LCD TV L32W698 has no sound suddenly
Check to make sure its not muted, if not then your main board most likely has failed
Dec 28, 2017 | Televison & Video
Picture fine for 10min.-then flickers(clicking sound)& then colors gone yellow
Looks like it's a color wheel problem-found a cleaning walkthru online, but it doesn't get rid of the loud hum form the CW motor. Also, it is thermal related-when the colors went out I placed a fan next to the color wheel and everything went back to normal. Several design flaws here and for $3000 these companies should do better-severe problems after a couple years is not acceptable.
Oct 26, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Envision color monitor, Model EN910e
Hi..there! Barb,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it. Have a nice day!
Oct 22, 2008 | Envision EN-7220 17" Flat Panel LCD...
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Envision Monitors L19W698 19 in. LCD TV Logo
70 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
