Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Need directions to fill , and how to use - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
  • 710 Answers
Hi
I have one just like it. Lay the machine back by pressing the pedal on the left side of the machine with your foot. Now you can get to the handle for the clean/dirty water tank. Lift this off. There's a clip in the back to separate the top sweep section from the tank. Take off the top. You'll see an open hole on the top for filling the bladder inside. This is for clean, hot water only. Fill the bladder, around the bladder is where the dirty water goes back in. you can drain the dirty water by pouring out the corner. There is also a plug on the bottom for draining the bladder when you're done.
When you put the sweep section back on the tank be sure to catch the front part over the edge of the tank or it won't stay on. Then fasten the clasp and put it back in place.
To fill the soap dispenser... find it at the back of the machine at the bottom. It just lifts out of the machine. Fill to line and reinsert.
Hope this helps.
Handy Andie
Posted on Mar 20, 2011
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
No manual for my Bissell Rug Shampooer
Follow this link. It is on bissells website and it is in PDF format so you can print it for free.
http://www.bissell.com/images/UserGuides/1696.pdf
Jun 29, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Shark Steam Mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
lli
Jun 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
May 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need directions
This is an older model Steam Cleaner. The upper tank, fill with hot tap water up to the fill line, then add 5 ounces of carpet solution to the water using the upper cap to measure. Make sure the lower letank is secured and turn it on, tilt the handle back, pull trigger to release solution to floor going forward, then release when pulling back slowly to extract. I am not sure if the manuals are available online, however you may be able to locate a Hoover dealer which may have a digital copy. They can be found through the hoover.com
Jan 19, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My first time using this..I just want to know where the water goes and where the soap goes..I don't have directions..I was looking for the directions on here but don't see it.. This is a bissell proheat...
hi,
okay the under the lid of the big tank has a place for regular hot water theres a flexible inner bladder inside the main tank- fill that with hot water. When your shampooing the dirty water fills in around it, also between the back wheels theres where the resolve/bissell detergent goes. we use regular washing machine liquid diluted 50/50 in the soap dispenser , its cheaper and does the same thing..also, if you have pets, the bissels have a brush roller mechanism that gets clogged with pet hair quickly and will self destruct, every few rows stop and see how much pet hair is around those rollers and remove it.
J
Jul 11, 2008 | Bissell Vacuums
Emptying the bag
Changing the paper bag...Just rotate the cardboard and pull until it comes off of the fill tube. Note the tabs on the fill tube top and the notches in the cut out circle in the cardboard on the paper bag when reassembling. Try this link for free shampooer directions.....manuals also available.
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope it helps,
Marci
Jun 25, 2008 | Vacuums
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
Note: Remember to secure the lid and test to
make sure it is secure before picking up the Tank.
6.
Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
