Question about Dryers
The dryer is not dying the clothes. It takes abou three times running it on a full cycle to dry.
  • Dryers Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Mar 20, 2011
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 | Dryers
How do I fix my clothes dryer?
check the lint filter and exhaust tube . if they are too full of lint the dryer will not work properly .
Apr 26, 2016 | Dryers
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Whirlpool Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
We have an LG DLEX8377NM dryer and are having problems with the drying cycle. We've owned it for three years and bought it new. It was professionally installed. We frequently dry clothes on the...
if there's heat in the dryer and yours is electric the most likely cause for dryer taking to long to dry is a blocked vent line,start the dryer ,go outside and check the outside hood where it blows out,make sure there isn't anything blocking it or a cage on it that's filled with lint,also every dryer should be opened up and cleaned,the easiest way is to get a shop vac,remove the front of dryer,vac up as much lint as you can see and then set the vac up to blow and blow the lint forwards so you don't have to remove the drum,then if the vent line is a long run i use a leaf blower,remove the vent line from the back of the dryer ,stick the leaf blower into the opening of the vent line and blow it out to the outside,hit it with short bursts at first so you don't damage the vent line if it isn't hard pipe,you will see a huge difference in the drying time.
Oct 01, 2017 | LG SteamDryer 7.3 Cu. Ft. 9-Cycle...
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
