Question about Fire Magic Aurora Island A660i-2A1N Gas Grill
As I typed previous gas is coming out of all the ports on the burners on the gril. They are not clogged. but gas does not travel around burner and get to one side. The holes have been cleaned. the BBQ is 3 years old. Fire Magic
    Brigadier General:
  • 4,736 Answers
When you removed the burners to clean them, did you also check and clean the venturi valves and the burner valve(s) orifice(s). If not, this may be the problem, as the burner(s) are not getting all the gas and the proper air to gas ratio, that they need for complete combustion.
R H Peterson the manufacturer of Fire Magic Grills has been around for years and makes one of the best high end grills on the market. Their Technical Service Department is top notch, so if all else fails contact them at 800-332-3973 or the Fire Magic Dealer you purchased the grill from.
Posted on Mar 20, 2011
Pilot stays lit but burners dont come on
Burners could be clogged from previous years of use- turn off pilot-then gas and remove and clean burner then replace and follow your steps backwards then start system
Oct 04, 2016 | Intertherm 56000 Btu Gas Furnace
Burner tubes clog up w/carbon daily and sparks are coming from the rear exhaust port
air fuel mix to burner not wright
check burner for holes
check injectors are clean
check burner air inlet is clean
check for low gas pressure to machine
Jan 10, 2016 | Kitchen Appliances - Others
I have a fire Magic A660 drop in grill (natural gas) and when I light the burner (2 of the 3 burners) the flame doesn't travel all the way around the burner. Gas is coming out of all the ports. I can light...
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Mar 18, 2011 | Fire Magic Grilling
Gas oven is working fine but none of the burners are igniting
The little gas ports maybe blocked on the burners, try cleaning the ports, also on the burners there are 3 or 4 small pin holes for the gas to travel, a small paper clip will remove any debris trapped inside these holes once they are clean the burners should light
Oct 30, 2009 | Ovens
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
Gas burners will not ignite ater cleaning stove top
hi friend,
On stove top burners that have sparklers that are not visible at the burner head, the burner heads have ignition ports. If the sparklers are functioning and the burners won't lite, chances are the ignition ports are clogged or restricted.
Ignition ports are tiny holes up one side of the burner head. If these holes are restricted, they must be cleared out. Cleaning can be accomplished using one of three methods.
Most commonly, a large sewing straight pin needle can be used. DO NOT enlarge the ignition holes. Doing so will have adverse burner lighting effects.
Burner heads where the flames will not burn completely around the entire circumference of the burner head, the holes which do not have flames are clogged up and need cleaning.
In cases of extremely dirty burner heads, soaking the burners in very hot water with plenty of dissolved automatic dishwasher detergent for several hours, rinsing and drying or a combination of both methods for heavily soiled burners.
hope this helps u
thank u for using fixya
please rate me..................
regards
sivaranjini
Sep 12, 2009 | GE Kitchen Ranges
Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
Apr 10, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Gas burner not igniting on Hotpoint RGB745, can smell gas
check to see if any of the port holes are clogged.. usually where the ignitor comes into the burner head
Jan 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Aug 03, 2008 | Thermador 31 in. SGS304Z Gas Cooktop
Fire Magic Aurora Island A660i-2A1N Gas Grill Logo
198 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
