Question about Goodman Heating & Cooling
Goodman gmp0503 unit has status light blinking slowly all the time. The indoor blower wont even come on when you switch from auto to fan on thermastat. The status light says for one blink to check gas flow, gass pressure, gas valve, or flame sensor. Good one of these problems keep the blower from turning on?
  • 1,420 Answers
Take a jumper wire and jump out the R and W terminals on the furnace. The heat should come on. If it does not, you have a bad board. A steady blink indicates no call for heat. You may have either a broken thermostat wire or a bad thermostat if unit fires when you jump it.
Posted on Mar 20, 2011
Goodman ac fan wont turn on
Indoor fan or outdoor fan? Indoor fan not coming on may be due to a open door switch. When the air filter is replaced or the door to the indoor fan may have a button switch that makes contact or closes when the door is in place and this switch if existent in your unit, is probably open. A safety feature for when the door is opened, no one gets hurt.
Jun 28, 2014 | Goodman Heating & Cooling
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
I have a goodman furnace model number gms80904bncc. When the temperature in house is met the blower continues to blow. Even if I put the thermstat in off mode the blower is still on
Hi #1 check thermostat : see if the FAN ON/AUTO switch is set to( auto ) and not( on)...If this is not the case turn the furnace switch off for 20 sec. and back on...did it stop? IF so the blower relay is sticking and must be replaced.
AUTO=BLOWER ON DEMAND/CYCLING
ON=BLOWER 24/7 all the time..
hope this helps
Nov 15, 2011 | Goodman Heating & Cooling
I turn the thermastat to heat on my goodman gms90904cxa and the inducer fan does not come on and after a couple of seconds the lights blink 3 times
Hello, a 3 blink pattern indicates a open limit switch. Most of the time a dirty filter, dirty blower wheel, weak blower motor, can cause the limit switch to open.
Oct 02, 2011 | Goodman Heating & Cooling
Indoor unit runs all the time in auto, outdoor
Your fan relay in the air handler is defective. Replace the fan relay.
Aug 29, 2009 | Goodman Heating & Cooling
Blower motor wont start
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It may be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Oct 22, 2008 | Goodman GMS90703BXA Heater
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Oct 20, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
155 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
