Adapter/power supply cord to hp speakers
The adapter with power supply cord for my hp sperakers for my computer got lost ion a move. Requirements for the unit are; 12 volt 1amp. Where can i find a replacement? Neither Radio shack nor Micro center were helpful and had no unit that would serve my needs.
    Problem Solver:
  • 9 Answers
Should be a marking on the speakers for polarity and voltage. Can get a 120VAC to DC adapter at radio shake.
Posted on Dec 19, 2008
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
Where can I buy a new power cord and adapter for this printer?
Try the following link: http://h20141.www2.hp.com/hpparts/Search_Results.asp?mscssid=3E1E07E2528A4EEA9925EC73FDB83FC8
If that doesn't work, try the following and enter "Officejet 4315" in the product name:
http://h20141.www2.hp.com/hpparts/?cc=US&lang=EN&jumpid=hpr_R1002_USEN
Select the model number from the back of your printer and then choose the option for Power Supplies.
I believe the parts you need are the following two: 0957-2119 8121-1023
Those may be entered as links that you can click on directly.
Hope that helps.
Apr 27, 2009 | HP Officejet 4315 All-in-One Printer
Lost manual for hp compact.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Mar 31, 2009 | HP Pavilion F1703 17" LCD Monitor
Polaroid FLM-2011 LCD
look at the back of your lcd it usually will state the voltage and power requirements of the required replacement adapter...never exceed the voltage requirements this may cause damage DO NOT USE THE 16V ADAPTER!
The adapter you require appears to be rated at 12V x 5A a 60Watt unit you can replace most likely with similar switch mode unit rated at 12V and at least 5A or more
Aug 25, 2008 | Polaroid FLM-2011 Television
Video upload....
well, the connector that comes from the 2nd speaker goes into the speaker port in the back of the first speaker.
The wierd cord possibly fits into the 12v dc slot in the back.. and the other end would go to a power adapter..
Seems you are missing a power adapter,, like you said earlyer.
Basically you would need a standard power adapter which fits into the speaker.
You could get some universal power adapter for it like
http://cgi.ebay.com/UNIVERSAL-DIGITAL-AC-ADAPTER-ADJUSTABLE-VOLTAGE-NEW_W0QQitemZ150275118131QQcmdZViewItem?_trksid=p3286.m20.l1116
Or
something to this direction
http://cgi.ebay.com/UNIVERSAL-AC-TO-DC-POWER-SUPPLY-ADAPTOR-ADAPTER-CHARGER_W0QQitemZ230275174536QQcmdZViewItem?hash=item230275174536&_trksid=p3286.m14.l1318
If you want to make sure you get the right kind of power apdater
Try contacting jbl directly
http://www.jbl.com/home/product_support/JBL_contactus.aspx?ProdId=PLATINUM%20SERIES&ProdName=COMPAQ:%20Platinum%20Series
I was looking around ebay, found this
http://cgi.ebay.com/NEW-JBL-Platinum-Series-PC-Speakers_W0QQitemZ260266345340QQcmdZViewItem?hash=item260266345340&_trksid=p3286.m14.l1318
Theres the power adapter in the middle, I think the odd cord goes to the back of the first speaker and the other end would go to a power adapter.. try contacting jbl they should be able to get you what you need.
Seems you have everything else you need except for the power adapter.
Jul 26, 2008 | HP JBL Platinum Computer Speakers
Power supply
dear gmonsta
u can buy a 12 volte 1 amp power adaptor....
and normaly on all computer speakers supply requirements are alrady given as instruction....at back side of u r speaker...
for more information on this topic u can mail me too sigma_shiva1@rediff.com
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
Nov 12, 2007 | Audio Players & Recorders
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
