Question about Food Processors
Kambrook kpf 80 drive belt is broken - Food Processors
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Blade not moving when food in mixer
Depending on model sounds like stripped nylon coupling , loose belt or broken cogs on drive wheel.. Meaning to much of a load in bowl has caused mechanical problem..
Feb 28, 2011 | Food Processors
Is there actually any one person in the entire world who knows how to take a Kenwood FP510 processor apart to change the drive belt? There are lots of queries on the internet but no solutions. Somebody...
I have solved it at last! Remove the 5 screws on the bottom. There are 2 more screws (which may be blackened with oil) located through the grille directly below the motor. They're stumpy little things with gripping washers. I had to bend the plastic grille thingys to get screwdriver in. Once released, these will enable the whole base to be removed. Then there are 3 screws to get the plate off to put the new belt on. Put the belt around the big cog. Replace the 3 screws of the plate. The motor drive is loose now so you can angle the drive cog to attach the belt to this. Using gravity by turning the processor on it's edge you should with some fiddling be able to put the stumpy screws back in - took me a couple of goes. Replace the 5 screws and robert is a very close relative.
Jan 29, 2011 | Kenwood Food Processors
The motor just humms loudly when I try to start it. If I give it a push it will start spinning, but boggs down if I put any food through it
Take the bottom plate off to expose the motor, drive belt, and pulleys (pull the power plug for this). Remove the drive belt and turn the motor shaft by hand--does it seem to turn freely? Do the same with the driven pulley--it should turn freely also. The pulleys and belt are likely cog-type and not prone to slippage. If either pulley shaft is excessively hard to turn, then investigate the reason,and replace parts if necessary. With the belt off, the motor should accelerate almost instantly. If relatively slowly, the motor may need to be replaced.
Jan 31, 2010 | Kenmore KFP-70 Food Processor
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
How to remove top cover moulinex masterchef a77
The Rubber cog unscrews anticlockwise to come off.
Sep 02, 2009 | Food Processors
Hamilton Beach Food Processor Type FP03 Model 702R Series
I just ordered a drive belt from https://www.goodmans.net/ for Hamilton Beach/Proctor Silex Food Processor Type: FP03 Model: 702R for $7.99 + shipping.
Sep 06, 2008 | Black & Decker FP1400 Quick N Easy Plus...
Food Processors Logo
101 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
