Will not spin dry... drains but wont spin.. I have a trouble code of 6 flashes which indicates a locked rotor. I have bypassed the lid switch. no solution as of yet. Thanks in advance.
  • 4,323 Answers
Hi
It seems that the lid switch is fine and the rotor should be replaced however, please post back with the manufacturers name and model no for further assistance.
Daniel
Posted on Mar 20, 2011
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Can i bypass lid lock simpsom ezi lock its broken
You have to replace the switch. It has a "failsafe" design which prevents users from splicing the wires together.
Jun 11, 2012 | Simpson Washing Machines
Hyundai washing machine spin not working
Hi.
Most spin problems are consequence of drain system faults.
The first part to check is drain system. Check the drain hose at the back and the drain filter attached to the pump. See article at the end for more detail.
Most machines' timer boards do an additional check on the lid switch before starting the spin part of the cycle. If the lid lock light is flashing and the machine does not spin the lid switch is probably defective.
The lid switch is tested jumping its contacts or reading Ohms at switch terminal. A two-terminals switch must read continuity (low impedance) when door is closed and must read open (infinity of Ohms) when door is open. If the switch is a three contacts, the third contact is called "heater". In that case there must be continuity between the three contacts with lid closed. If the model instead of a simple switch uses a wax motor, then the lock cannot be tested by jumping contacts. The lock motor must be tested reading Ohms and checking that impedance is the same as indicated in service manual.
If lid switch and drain system are OK, then the pressure switch must be tested.The pressure switch detects the water level and among other things determines when to advance the cycle to spin.
If all the above is OK, then the motor and motor control unit (if present) must be tested.
Please read the solution in the article below for more:
If you have no spin ...
You can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 04, 2011 | Washing Machines
Not spinning but stil aggitates
Hi.
Regards.
Ginko
Aug 28, 2011 | Whirlpool Washing Machines
Lid lock light keeps flashing and machine wont spin
Hi.
Regards.
Ginko
Aug 21, 2011 | Washing Machines
Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut the blue wires and discard the reed switch. insulate the ends of the blue wires and push them back into the track in different directions so there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9. Cut the white wires at the contacts, strip 5mm of plastic off the wires and twist them together, The wires will have corrosion, clean them with sand paper, they must make good contact. I recommend that you solder them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
Jul 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
My washing machine does not have a spin cycle
I just solved this problem myself. It's the lid lock mechanism which is located under the top cover. When I manually moved the aluminum locking tab over my washer prompty drained and spun. There are four wires total going to the switch. Well, the solid white and the white/red wires control the lid lock mechanism. You can either replace the entire switch or bypass the lid lock by wire nutting the two wires I previously mentioned together. Now, if you bypass, be forewarned the lid will open while the washer spins very fast which presents a potential danger. For immediate use, bypass until you get the replacement switch. Hope this helps your problem.
May 10, 2009 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
