Question about Concord Fans CC-RM-08-R Remote Control
I have a concord wireless fan control that mounts in the wall. The lights and fan will come on whenever they want. What can i do to fix this problem
I purchased a Universal Wall Mount Control to operate a current wireless controlled fan with a hand held remote. Why is the wall mount control not operating fan with fans original receiver?
Depending on the age and brand of the fan it could have dip switches on the receiver, the part of the remote control unit that is either up in the canopy of the fan or it may be built into the fan, and the wall control ie transmitter may not be compatible with it. When replacing a remote control unit it is advisable to replace both since it could be either the receiver or transmitter.
Jan 03, 2017 | Dryers
I have a 3 speed fan controlled by 3 speed wall switch; fan hums on low, louder hum on medium, and high position eliminates hum but speed reduced to low. Is it the fan or the wall switch?
Check the capacitor (black box with wires going to switch) and see if that's going bad. If it's not that, take the control out of the wall and just use the pull chain to see if it runs correctly. If it does, you need a new wall control. DO NOT USE A DIMMER SWITCH!
Aug 04, 2014 | Concord Fans PB-1032-ORB ARACRUZ Oil...
I have a concord fan model 820AL-G I only get a signal from the fan when the wall controller is activated the fan will not function has anyone experienced this problem
Thinking the fan has to be on to use the wired wall control. If you pull the chain switch it is just turning the fan off and then neither will work. Just use the wall control or get fan with wireless remote maybe.
Jan 10, 2012 | Concord Fans PB-1256-EMN GRANDEVILLE...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
Controller (s) not working
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
May 15, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Concord Fans CC-RM-08-R Remote Control Logo
120 people viewed this question
Top Concord Fans Televison & Video Experts
Are you a Concord Fans Televison and Video Expert? Answer questions, earn points and help others
