Question about Dryers
Drum will not turn if more than 3 shirts are put in it.
    Genius:
  • 1,114 Answers
It sounds like you have a bad belt. This is a fairly simple repair, and you can accomplish it yourself if you have some tools, and a little time. I would recommend that you get the model number, go to an appliance repair shop, get a belt, and then replace it.
Posted on Mar 20, 2011
Why does my Kenmore front loading dryer which is only a year old shreds our clothes!
call sears and gripe about it seems I read about one that the fins were loose and they had to replace the outer drum the wet clothes put too much pressure on them and they flexed
Mar 09, 2015 | Kenmore Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Shirts getting stuck on "ledges" inside drum
Try these "dryer balls":
http://www.amazon.com/Dryer-Balls-Original/dp/B000BOBM8O
Apr 07, 2010 | Roper REX3614KW Electric Dryer
Won't start
most of the time it is a weak motor going bad,to weak to turn the drum-mike
Feb 06, 2010 | Kenmore Dryers
Dryer sped too fast?
Put a couple of clean dry bath towels in with your knit shirts.......problem solved
May 29, 2009 | Whirlpool LEB6300 Electric Dryer
Dark spots on clothes coming out of dryer; clothes clean when cycle started
could be some u left in one your shirt are pant that fell out in dyrer an caugth between the drum seal
Feb 27, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
Front Load Washer Seal
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Maytag EPIC MFW9600S
Holes in clothes
run a old hosiery or cotton wad (like from holloween) around the inside of the drum. see where it snags,
the drum is warranted for a very long time. (don't know exact)
Mar 26, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
426 people viewed this question
Top Dryers Experts
Marvin
Marvin
