Question about Linksys WRT120N Router
Im trying to open the ports "3784, and 6100" for Ventrilo and i can not get them to work.
    Master:
  • 451 Answers
You will need to setup your computer for a static ip address.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Tahoma} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Tahoma; min-height: 14.0px} span.s1 {color: #05aef0} span.s2 {font: 12.0px 'Lucida Grande'}
Click the Security link near the top of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Enter the name of the program into the Application box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
If you are forwarding a single port, enter that port number into the Start and the End boxes. If you are forwarding a range of ports, enter the lowest number of that range into the Start box. Then enter the highest number of that range into the Endbox.
Use the Protocol drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Posted on Mar 20, 2011
Can't connect to ventrilo
Make sure your router has the correct ports open on both your router and that Windows Firewall and/or your personal firewall has allowed access.
Vent needs port 3784 open on both UDP & TCP.
Aug 31, 2009 | Computers & Internet
Tip
How to back up using Ventrilo
<p>Ventrilo is an application that a web server and you can chat with other registered users. Ventrilo is often used in games will allow players in multiplayer games, real-time interaction. Some users have programmed several Ventrilo server setup on the machine. Ventrilo safe is copying a specific file on the backup device. This ensures that your server settings, copy the file, you do not recover your hard drive. <br /> <p><br /> <p>1. Click the Windows Start button. Click Open "Computer" from an Explorer window. Double-click the C drive to a list of folders on your computer to see. <br /> <p><br /> <p>2. Double-click the Documents and Settings folder. "This is a folder with the profiles and preferences of the user. Each user has a separate folder. The folder is labeled with the user. Double-click your user name in the list of folders. <br /> <p><br /> <p>3. Double click "Application Data", double click on "Ventrilo". This folder is the file "ventrilo2.ini. This includes all settings for Ventrilo. Right click on the file and choose Copy. <br /> <p><br /> <p>4. Click the Windows Start button and click My Computer. Right-click the drive where you want to copy the settings Ventrilo. This may be a CD or DVD, or you can use on an external hard disk. Click "Insert" to back up your settings in Ventrilo to create. <br />
on Jun 22, 2011 | Computers & Internet
How do I Enable port forwarding to port 3866 UDP and TCP to get Ventrilo to work?
1. you don't need port forwarding to get the vent client to work.
2. if you're having issues doing port forwarding to your vent server, then you need to check out port forwarding instructions for your specific device - which can be found organized by manufacturer here.
Aug 23, 2009 | 3d Rose Londons Times Funny Music Cartoons...
Ventrilo 3 stuck at synchronizing, cant connect.
This problem normally appears when using routers and having NAT enabled
To Fix this do the following:
Feb 22, 2009 | 3d Rose Londons Times Funny Music Cartoons...
I cannot connect to port 3997
I would first try to connect to other ventrilo servers on other ports. Make sure it's not your vent program. Next I would make sure you are not having issue with your windows firewall or a third-party firewall (Symantec/Norton/McAfee etc). Disable them temporarily to test. Because you can not connect via telnet tells me something is blocking your port. How about the router/firewall? Is it new? If so, try replacing it with a known good one.
Jan 31, 2009 | Computers & Internet
World of Warcraft
Sounds like you need to do some port forwarding.
World of Warcraft communicates on port 3724 with the TCP protocol. The patching process requires port 3724, 6112, and 6881-6999. Once again to download the patches for World of Warcraft you should forward the following ports.
3724 TCP6112 TCP6881-6999 TCP
If you can not forward ranges of ports and are only planning on having one computer playing WoW, just forward ports 3724 TCP and 6112 TCP. The 6881-6999 port range is mainly used where multiple computers on a network may be trying to play WoW at the same time.
Ventrilo: From their web site: Click on the "Port number" input box and enter the servers port number. The program will automatically display the default port number of 3784 but you can change this to what ever the server needs it to be.
So forward 3784 or the port number you chose.
http://portforward.com/english/routers/port_forwarding/Motorola/SBG900/SBG900index.htm for a walk through on how to do the forwarding.
Hope that helps!
Jun 02, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Can hear everything except my girlfriend ):
Is it through an IM program? If so I had a simular problem and I open the sound settings and made sure non of them were muted and it worked fine after that.
Apr 23, 2008 | HP Pavilion dv6000z Notebook
My mic aint working
most likely a broken wire inside. it's dead imo.
Apr 14, 2008 | Koss SB45 Professional Headset
Logitech headset
the logitech headset doesnt require drivers it should work right away after plugin in
try with another pc if the problem persists then its a faulty headset if not then you need to reinitialize your usb ports.
Feb 19, 2008 | Logitech ClearChat Stereo Headset Headset
Headset paired but doesnt function in ventrilo
Did you ever figure out what was wrong. Mine is doing the same with my LG shine. I will have to take it in for service. You had the problem quite awhile ago. Hoping you got an answer.
Oct 24, 2007 | Jabra BT125 Headset
Linksys WRT120N Router Logo
154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
